TPI intake for LT1
Old Jan 22, 2008 | 08:23 PM
CamaroSS8887's Avatar
TPI intake for LT1
I saw this on the pace performance website.... Can this really work on an LT1 and will it flow better cause i feel the LT1 intake has to short of intake runners. http://paceperformance.com/index.asp...ion=PRODSEARCH
Old Jan 22, 2008 | 08:25 PM
http://paceperformance.com/index.asp...&ProdID=105249
Old Jan 22, 2008 | 08:48 PM
jay_rich's Avatar
I know alot of TPI guys on TGO run LT1 intake so maybe but i dont have a clue, but if there flow better why are they usings LT1 intakes???
Jay
Old Jan 22, 2008 | 08:57 PM
96capricemgr's Avatar
The LT1 makes surprisingly good torque despite the short intake runners. The aftermarket TPI intakes HAVE been adapted and if it were worthwhile it would catch on better than it has.
No need to reinvent this wheel, just choose duration, compression and heads correctly and they can be torque monsters.
Old Jan 22, 2008 | 09:03 PM
Green96Z's Avatar
From Chevy High Performance (http://www.chevyhiperformance.com/te...d/index.html):
As is almost always the case, however, the road to horsepower goes through the cam, heads, and intake manifold. "The factory cylinder head is a really good base," Golen observes. "It flows good with fuel, and with porting it will support up to 530 hp." Ditto the factory intake manifold. "It's just a very good design," says Golen. Again, with porting, power levels approaching 530 hp are supported.
They were talking to Chad Golen there, from Golen Engine Service.
The LT1 intake is already a great piece. It's been tried and tested, just use the search to bring up the stock vs. Edelbrock discussion. I wouldn't waste your money.
Old Jan 22, 2008 | 10:46 PM
LSWHO's Avatar
TPI guys run the LT1 intake for the horsepower. There's a reason though why the LT1 came AFTER the LB9... it's better. Same with the LSx. I prefer LTxs over ANY LS1, but I can't deny their superiority.
Old Jan 23, 2008 | 03:29 PM
Gtpguy's Avatar
Will it fit under the low 4th gen Fbody cowl is another question. The TPI intake is a bit taller than the LT1 intake.
Old Jan 23, 2008 | 03:54 PM
A complete "stock" TPI intake is of limited value. Yes, the L98 with longer runners made more low RPM torque than the LT1, but it ran out of breath at 4,500RPM.
The base you linked can also run with the Super Ram plenum..... add another $500+ or so for that piece. Lingenfelter did some work with the Super Ram, and seemed to feel it was only applicable to the A4 cars... not sure why.
After 15 years of LT1 history, I can't think of too many people who have gone to the Accel intakes. A buddy of mine had one.... the mount for the throttle body has to be angled down to allow the hood to close. He never did anything with it though.
Old May 14, 2008 | 12:31 PM
Compcnc's Avatar
Golen has CNC ported intakes available now also. As well as CNC ported heads.
I hear that the new CNC ported heads they are offering now are the most powerfull factory castings they have tested to date.
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
dansam
Jul 20, 2002 01:10 PM
