tourque converter knock
Old Sep 13, 2003 | 09:46 PM
pearlpurple's Avatar
Can your tourque converter knock making it sound like you have a bad main or con rod bearing??
Bolts are tight, no cracks in flywheel but when under neath the knock sounds like it is coming from the converter. Took my stethoscope and tried different spots around the engine and can't hear any knocking.
Old Sep 14, 2003 | 07:57 PM
Anyone have any idea??
TTT
Old Sep 14, 2003 | 08:05 PM
12SCNDZ's Avatar
The only time I've heard one make a noise like that is if the flexplate is cracked, or a bolt is loose, but you say you've checked those 2 things.
Frank
All-Trans Transmissions
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
