tourque converter knock
Can your tourque converter knock making it sound like you have a bad main or con rod bearing??
Bolts are tight, no cracks in flywheel but when under neath the knock sounds like it is coming from the converter. Took my stethoscope and tried different spots around the engine and can't hear any knocking.
carguyshu
Jan 22, 2017 11:19 AM
