Top Speed
Old Oct 19, 2003 | 10:19 PM
  #31
S8ER95Z's Avatar
Look.. i dont care what some of you guys THINK you know about this... Maybe some models didnt have a fuel cutoff...who knows. Fact of the matter is I can push the needle past 150... down into the dash and the car doesnt stop increasing in RPMs until I let off... (5300rpm in OD w/ 3:42s) Regardless thats WAAAAAY past 155mph. I have done nothing to the stock programming. Which from my understanding should have a value of 255 in the limiter setting. Could be on a year by year basis... however in 95, A4, w/ 3:23s factory optioned QLZ... I DO NOT have a limiter.
Old Oct 19, 2003 | 10:26 PM
  #32
madwolf's Avatar
I haven't read the whole post, but here's some info I gathered from experience.
93-95 cars with non z rated tires and an older PCM calibration were limited to 108 MPH and received a 110 speedo.
94 and 95 cars had a newer calibration from GM which raised the limit to 118 MPH.
93-95 Z-rated cars all had the speed limiter set to 255 MPH.
96-02 F cars with non z-rated tires all had 118 MPH speed limiters.
96-02 F cars with Z rated tires were all limited to 160 MPH.
Yes, it does cut fuel for that instant, both when it hits the rev limiter and/or the speed limiter.
Old Oct 19, 2003 | 10:32 PM
  #33
NOMAD's Avatar
Cool
Originally posted by madwolf
I haven't read the whole post, but here's some info some of you might find useful.
By golly, i thought I knew my car. 95 Z.. Limit of 255
I sure hope you OBD1 swap guys read this too
-Shannon
Old Oct 19, 2003 | 10:34 PM
  #34
jonaddis84's Avatar
Thank you madwolf, finally this is settled, i dont think anyone can argue with him. That is why us with 93-95 Zrateds are arguing no limiter and others are saying limiter.
Old Oct 19, 2003 | 10:37 PM
  #35
madwolf's Avatar
No problem. If anyone wants to verify the above, just give me your VIN number and I'll tell you.
I have the GM flashing software so I have access to any tune from any year.
Old Oct 19, 2003 | 11:16 PM
  #36
JONEZ_Z's Avatar
John addis,
40pounds of oil pressure at 5500? Is that right?
Old Oct 19, 2003 | 11:22 PM
  #37
jasons93z's Avatar
u guys really shouldnt be going 160+ anyway . Ive only taken it up to 130.
Old Oct 19, 2003 | 11:32 PM
  #38
b-stevens's Avatar
Originally posted by JONEZ_Z
John addis,
I was just going to say that exact same thing
Old Oct 19, 2003 | 11:54 PM
  #39
S8ER95Z's Avatar
Thanks for clearing that all up!!! I think we all have an answer now right?
Old Oct 20, 2003 | 12:07 AM
  #40
cndctrdj's Avatar
i hit my rev limiter in 6th gear one time.
ok now that you all think i am nuts.....
my clutch was slipping so bad that i actually did hit it. i was only going like 140ish. about 2 months later my clutch was completely gone.
i know that this doesn't mean much but i thought it was funny.
Old Oct 20, 2003 | 12:15 AM
  #41
Transamdriver's Avatar
Originally posted by Mystic97Z
lol!!! who is this guy???
Dude you need to RTFM! A couple header swaps and he's now the F-body Genius! Watch out folks and take all questions to this guy.
Old Oct 20, 2003 | 01:58 AM
  #42
FireHawk409's Avatar
When i first got my Power Programmer it showed me what my stock settings were. 255 was what my speed was limited too.
Peace
Omar
Old Oct 20, 2003 | 02:05 AM
  #43
siggs229's Avatar
Originally posted by 97Z-M6
yes it is. with z rated tires my car shut down at 155 it takes some changing in the pcm via tunercat or lt1 edit to rmove this.
trust me. every car (fbody) had a speed limiter on it from the factory. and the highest is 155 some came with 108 i bekieve and i think that was 93 and 94 ( could be mistaken on that though)
you may have bought one that someone had instaled a hypertech and removed the limiter, but if it is stock it 155.
if you have tuner cat look at the stock file on your car in the constance table and it will show the speed limiter. if you dont have a stock file to read i can send you one i got off the net from brents page. but that only if you have the software to read it.
by the way who told you this. a magizine or something.
You are exactly right .
Old Oct 20, 2003 | 09:46 AM
  #44
Acct 23749's Avatar
NOMAD and Mystic97Z
What i said was corect, i just didn't know the exact speed for each year. there is a fuel cut off on all cars at certain speeds. and if you ask madwolf when you hit for example 160 it will cut fuel momentarily and then add it back not allowing you to excede 160.
I think you guys miss understood "cut fuel" and though it ment your car dies leaving you with no PS or brakes. It only cuts the fuel for how long you tell it to. in most cases including stock, it is set to resume fuel flow at the same speed as the fuel cut off.
I also believe it cuts it via injectors, and it may not cut ALL cylinders, but a couple of them.
I know mad wolf knows what im talking about, there is a Cut fuel and resume fuel speed/RPM for all 3 limiters (speed, 1st gear RPm and 2nd-6th gear RPM)
Old Oct 20, 2003 | 09:57 AM
  #45
ishz28's Avatar
Kinda important about the top speed. Doesn't the stock steel drive shaft have a terminal velocity of 153 Mph and the aluminum one, 202 Mph?
