Top Speed
Old Oct 19, 2003 | 12:54 PM
JAG05's Avatar
Top Speed
I was wondering what the top speed is on my stock 94 camaro z28?
Old Oct 19, 2003 | 12:56 PM
Cmr0z28's Avatar
mmmm somewhere around 162mph i believe.
Old Oct 19, 2003 | 01:41 PM
97Z-M6's Avatar
the pcm will shut the fuel off at 155
Old Oct 19, 2003 | 01:56 PM
Cmr0z28's Avatar
LOL where do u get this from? only cars with non z-rated tires from the factory have a top speed limiter which is around 113-114 mph usually.......not 155. if the car came with Z-rated tires from the factory, it doesn't have a top speed limiter
Old Oct 19, 2003 | 01:59 PM
joeSS97's Avatar
Faster than you should go.
Old Oct 19, 2003 | 02:13 PM
Gloveperson's Avatar
I recall a Car and Driver issue when the car first came out that rated it at 156 mph.
Old Oct 19, 2003 | 02:19 PM
N2OpwrdTA's Avatar
I think they do have a speed limiter. When I got LT1 edit and first looked at my PCM, it was limited to 157mph...via the limiters parameters/mph settings for fuel cutoff.
However, on another note...I think all lt1s were set slightly different according to tires, rear gears, tranny, etc...If someone else knows otherwise(like Ion(madwolf))...then lets hear it.
I remember seeing many reports of the auto 94 camaro z28(with the 2.73 gears) going 162-163mph. I think that one reason why some state cops like to use that model for highway patrol cars.
Old Oct 19, 2003 | 02:31 PM
Critter's Avatar
before i put in a corvette servo mine wouldn't shift out of 3rd at full throttle................afterwards i could bury it...........hey it was high school..............so the limiter is in the actual tranny and mine wouldn't go past 120.....with the original 3:23'3 if you wad the 2:73's it would be higher........
Old Oct 19, 2003 | 02:35 PM
97Z-M6's Avatar
yes it is. with z rated tires my car shut down at 155 it takes some changing in the pcm via tunercat or lt1 edit to rmove this.
trust me. every car (fbody) had a speed limiter on it from the factory. and the highest is 155 some came with 108 i bekieve and i think that was 93 and 94 ( could be mistaken on that though)
you may have bought one that someone had instaled a hypertech and removed the limiter, but if it is stock it 155.
if you have tuner cat look at the stock file on your car in the constance table and it will show the speed limiter. if you dont have a stock file to read i can send you one i got off the net from brents page. but that only if you have the software to read it.
by the way who told you this. a magizine or something.
Old Oct 19, 2003 | 02:42 PM
Critter's Avatar
yeah what i said was just the 4l6oe's so anything else don't ask me
Old Oct 19, 2003 | 02:45 PM
robb4964's Avatar
Yeah it does , I have a road tests on many 93-95 f-bod LT1's in my old car and driver /road and track reviews , Most of them are rated at 160 , some at 150 . Unless like you said they come w/out z-rated tires .
Old Oct 19, 2003 | 02:50 PM
97Z-M6's Avatar
gm or a magizine can rate them at a top speed of 1000mph it doesnt matter when the pcm cuts the fuel off a 155. being rated and being limited are two difernt things.
Old Oct 19, 2003 | 02:56 PM
robb4964's Avatar
EVERY BODY HAS A SMART MOUTH AND THINKS EVERYBODY ELSE IS STUPID ...RATED , WHEN ITS RATED IT WILL HAVE A ICONS , ONE MEANING "LIMITED " MEANING EXACTLY THAT " LIMITED " thanks
Old Oct 19, 2003 | 02:57 PM
NOMAD's Avatar
I've never heard of the PCM shutting off the fuel at 155, so i'm not sure where anyone's getting this from. If your car came from the factory with Z rated tires, you do not have a speed limiter. If you have regular tires, your speed limited around 118.
The only time the engine shuts off the fuel is when you hit the REV limiter.
I've had my car over 165 a couple of times and I had stock programming then.
From what I understand you can go 187 with 3:23 gears in it if you don't factor in aero drag and parasitic loss in the drive train. That should be when the car hits the rev limiter.
-Shannon
Old Oct 19, 2003 | 03:02 PM
jonaddis84's Avatar
My stock file said fuel cutoff at 255mph, not ever messed with either. Plus I buried it well past 155 when I first got it, but as soon as you go into 6th it doesnt have enough power to pull anymore and it slows down...not next spring though
