Too many miles to mod?
Hey all. My LT1 just crossed 80,000 miles a few days ago. I would really like to mod the car some, but do you think I have too many miles to mod it? Should I rebuild it?
It seems to run fine to me. Always starts up the first time. I don't really know how to tell if its not running to its full potential. How much would a full rebuild cost?
Just give me your thoughts.
there are guys with 170,000 miles putting in cams and heads...i just hit 101200 miles and am going for heads, headers, and cam...these cars will run a long time with proper care and maintenance...just dont drive it hard and put that kind of abuse towards it and you will be fine....80,000 miles is just getting broke in
Yea really.
My car is about to hit 78,000 and i'm getting ready for a Nitrous setup (100 shot)
Make sure u maintain regular maintenance and give it a compression check every now and again. watch oil pressure, and make sure u have enough oil so u don't spin a bearing. other than that, have fun and happy modding!
I have approx 209,000 miles on my '94 z28 w/ stock bottom end (everything original ) plus mods in sig and I'm getting ready to add NX wet kit-100 shot. If you take care of them, they take care of you. At 80K, you're just getting it broke in if it has been take care of properly (i.e. oil changes, etc). Don't Rebuild, Build !!!
I hope i make it to 200K mi. I just hit 100K.
An engine with 50k could be run into the ground and when someone adds mods it poops the bed. OTOH, an engine could've been very well maintained, have 100+k miles on it and stand up to a heads & cam just fine. I did my cam with 103k miles on the odo and all has been well (113k now). I don't go to the track, but I don't totally baby it all the time either. Every situation is different. You have to make the call..
Shoot, I hope I make it to 60K. I just hit 40K this year. I say build your engine up. I'd just save some cash just incase something does happen. But in this hobby it's likely to happen to any one, new or used.
Originally posted by FastZinTennessee
130k miles on mine, did heads and cam 5k ago. So far the motor has been fine with the extra power and 6200 rpm.
John
John
Benji
Originally posted by Sweetred95ta
Same boat here!! Except I spin to 6500 with no problem. Car is stronger than ever. My cylinder walls looked like they had 30,000 miles on them when I had it apart at 122,000. Now its at 128,000 and still doin fine. Mod it!
Benji
Benji
John
I threw a set of ported heads and a CC305 at a 94,000 mile bottom end. It went 12.38 @ 111.9 MPH 2 weeks ago .
Surprisingly, even with that many miles, the cylinder bores were still in great shape. It still has 70# of oil pressure idling/cold & 35# idling/ hot...With regular Pennzoil 10 W 30.
Frank
Frank
10-31-2016 11:09 AM
