tips on installing a cam
Old Apr 1, 2007 | 10:50 PM
lt1chevelle's Avatar
well took apart the motor and iam going to be installing a gm847 cam once i get my heads back from loyd. this is my first time installing a cam into a lt1 motor got any pointers? also what is a good dual timeing chain to run the motor is a 95 so i think i can run one? also when i go to put the opti spark back on do i have to line any thing up for timming? i never really under stud how u time this thing sence there is no distribuator. well any pointers would help me out
thanks
Old Apr 1, 2007 | 11:09 PM
sworaz
Guest
Posts: n/a
Go in straight and slightly rotate, make sure it's well lubed. Don't score any journals! Might want to start a couple of longer screws in the end of the cam to help get a good grip on it. As far as the opti; the dowel pin has to line up on the bigger indention on the back of the opti (there will be 3 of them it's the bigger one). Good luck!
Old Apr 2, 2007 | 07:05 AM
94_PatriotRed_Z's Avatar
A good timing chain for a cam like that in a 95 is the GM heavy duty set. Which I just happen to have a brand new one for sale, for $275 + shipping, they sell for $330 from Thunder Racing.
GM Extreme Duty Timing Set
Old Apr 2, 2007 | 07:11 AM
rskrause's Avatar
Moderator
Unless you are using an electric WP you must use an LT1 specific timing set, which has the gear to drive the WP. Otherwise, if using an electric WP, you can use any regular SBC set (the cover may need clearancing).
rich
Old Apr 2, 2007 | 07:14 AM
rich
This one is for an LT1, with a vented opti('95-'97)
Old Apr 2, 2007 | 07:16 AM
It does have a distributor. It's called the optispark. You can find guides and info on my Tech Page that might help you.
Old Apr 2, 2007 | 07:28 AM
1997blackz28's Avatar
this is a good timing set to run with the stock waterpump. this is what i run on my lt1
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 2, 2007 | 08:43 AM
iam running an electric WP, ill have to take apart my optispark and make sure i put it together the right way
Old Apr 2, 2007 | 08:02 PM
ztwenty8's Avatar
is it absolutly neccessary to run a 95-97 opti on these timing chains?
Old Apr 2, 2007 | 08:22 PM
yes because on a non vented opti('93-'94), there is a sprocket that drives the opti off of the main timing chain sprocket, and with a vent opti('95-'97) the dowel pin drives the opti. Unless you change your '94, to a vent opti, which will require a new timing cover, possible a new cam, a new intake elbow, and a new vented opti.
Old Apr 3, 2007 | 12:55 PM
06lingenfelter's Avatar
try to keep the back of the opti the same way it came off. but if not just make sure you line it up right when you put it back on. if i remeber correctly there is a little notch on the back of opti that you should line up with the dowel pin on the cam. the 3 leaf clover looking thing, don't force it on it will slip right on and you will know.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
