tips on changing my spark plugs?
Old Dec 28, 2006 | 12:09 AM
justinsbad95z's Avatar
I started to change my spark plugs in my 95 z 28 and had no idea how hard they were to get to. Are there any tips or special tools that will help me?
Old Dec 28, 2006 | 12:16 AM
silentsprintero's Avatar
get a spark plug socket (5/8" with the rubber hole in the middle) that has flats on the end of it too. i found it a little easier to use a thinner wrench that can grip on the flats of the socket rather than having a giant socket wrench to move around and clip into the socket. try searching on here i think there are a few threads that have good hints at it though
-Chris
Old Dec 28, 2006 | 06:35 AM
rskrause's Avatar
Moderator
Do a search and buy a case of these:
Rich
Old Dec 28, 2006 | 06:42 AM
GetaZforgetGT's Avatar
And a case of these:
Old Dec 28, 2006 | 06:52 AM
rskrause's Avatar
Moderator
LOLERS
I forgot the most important part!!
Rich
Old Dec 28, 2006 | 07:20 AM
cehan's Avatar
-Chris
This socket will help a lot, but I went ahead with mine and cut it down to a total length of 2" with a die grinder and cutoff wheel. That makes it easier to get at a couple of them, especially #6 & #8. Also, when I am ready to torque them down, since there's no way to get a torque wrench in there, I take a magic marker and number the flats on the socket. That way if I want to go 1/3 turn past hand tight (that would be 2 flats), it's easy to keep track of where you're at because you will be repositioning the wrench on the socket several times before the plug is completely tight.
SLP used to sell a socket like that, I think they wanted like $20. You can do the same thing yourself for just the price of a regular spark plug socket .
Old Dec 28, 2006 | 07:30 AM
transAMdriv3r's Avatar
i found that getting plug number two was easiest to get to sitting on top of the engine because of those steel lines. just a tip
Old Dec 28, 2006 | 12:33 PM
SantaCruz163's Avatar
Drivers side is cake from under the car.
Passanger side #2,#4,#6 are cake also.
The only plug I had a difficult time with was #8. It's too far to reach from up top, and a pain to get you hand in there from the bottom. I ended up dropping the starter and had my brother guide it up from the bottom while I got it in from up top.
Total time to change plugs was <2.5 hours.
Old Dec 28, 2006 | 01:14 PM
01Z's Avatar
01Z
Here's the tools I used:
I can't express how important it is to have one of those short swivel end extensions.
Old Dec 28, 2006 | 02:54 PM
97Camaro007's Avatar
Also removing your starter will help you with the back 2 plugs on the passenger side.
Old Dec 28, 2006 | 02:59 PM
jsetzer's Avatar
Get headers
Old Dec 28, 2006 | 03:01 PM
reamo04's Avatar
i just did mine the other day in about 2 1/2 hrs on stock manifolds
driver side - do from the bottom
passenger side - you can do the back 3 from laying across the motor
the front one, take the alternator off, it'll make it so much easier
Old Dec 28, 2006 | 04:00 PM
KillWhitey's Avatar
A set of longtubes will make it much easier
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
