Regular Oil vs High Mileage Oil
Old Dec 28, 2006 | 12:07 PM
micfly83's Avatar
I got a 95 Z28 with 110,000 on the ticker.
I started using Valvoline 20w50 oil at about 108,000 due to some leaking issues and the engines age.
I then noticed that there is some "75,000 High Mileage Valvoline 20w50" oil.
Would this help my engine at all. Maybe help the seals and all that vs just the normal 20W50, or will it create problems.
Old Dec 28, 2006 | 12:31 PM
BUBBA's Avatar
You will find as many opinions as there are types of oil. If you aren't having any problems with your present oil, then it would probably take a long trial period to determine any difference. With a relatively high-milage vehicle, I would stick with good quality dino oil and change it regularly along with the filter. JMHO
Old Dec 28, 2006 | 12:46 PM
razor02097's Avatar
High milage oil is a ripoff IMO. unless you are having problems with your current oil I wouldn't change what works.
Old Dec 28, 2006 | 12:51 PM
micfly83's Avatar
Well I was having problems with some white smoke comin out the back.
I was told it was a head gasket, then I was told I was just leaking oil.
I was told to put in a heavier weight oil and so I did, and that pretty much curred the problem for the most part.
So yes its working. I'm just wondering if high mileage stuff would be better in that it would freshen up some of the seals all that and maybe be better than what i have now
Old Dec 28, 2006 | 01:02 PM
razor02097's Avatar
as a mechanic I can say that when a seal is damaged enough to leak there is little you can to get it to stop besides replacing it.
Im just saying you shouldn't waste your money. Instead spend an extra few bucks on a high quality oil filter.
Old Dec 28, 2006 | 02:25 PM
micfly83's Avatar
Yea
But like i said, the 20W50 oil did real well at solving whatever the problem was.
Its probably just a temporary fix though, but its been good for a couple months so who knows.
I'm just wonderin if theres any negative affects of using a "high mileage" oil.
I thought I heard things like running synthetic oils in high mileage engines is bad, and stuff like that.
Also the engine is apparently "rebuilt" with 15K on it. I dont know if i was lied to or what, with the white smoke and all, but does this have any affect on using high mileage oil since the engine is theoretically 15K miles old...i guess.
Thanks so far guys
Old Dec 28, 2006 | 02:34 PM
Mikes 1994 z28's Avatar
Ive heard high milage engine contains additives that clean more then regular oil.
Old Dec 28, 2006 | 02:38 PM
"White" smoke generally relates to a head gasket problem, not burning oil.
Old Dec 28, 2006 | 03:25 PM
razor02097's Avatar
Yea
Thanks so far guys
I don't think there are negative affects from running the high milage oil might make your car faster by making your wallet lighter.
Synthetic oil in a car that burns oil or leaks oil won't hurt it but it will leak and or burn the synthetic oil too. I run synthetic in my 94 Z and my jeep I don't run it in my 89 camaro cause it has over 200K miles on it.
like Injuneer said white smoke isn't oil burning. Blue smoke = oil burning
Old Dec 28, 2006 | 06:06 PM
Gun5's Avatar
my nissan maxima im working on currently white smokes for startup for about eh 5-10 mins i changed it from the crap 5-30W (ran some engine gunk cleaner through ti first though) then i changed to high mile EXXON (cheapest stuff I could get) 10-30W stopped the front main seal oil drip
HectorM52
Jul 30, 2017 11:46 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
carl.froehlich
Mar 13, 2015 12:38 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
