Those with the LE3 kit...
Old Mar 2, 2005 | 10:43 PM
1995ta's Avatar
How do you guys like it? Anyone running it on an A4 setup? What gears and stall do you have? Anyone have some dyno sheets or sound clips I can hear?
I plan on running this package along with my fully forged 355 either to be sprayed big time or boosted around 12-16 lbs.
Old Mar 2, 2005 | 10:45 PM
turbo_Z's Avatar
Re: Those with the LE3 kit...
Im gonna guess the LE3 cam is an NA cam. Not the best thing for spray or boost. Go with the LE3 heads for sure man but pick a different cam!
Old Mar 2, 2005 | 11:08 PM
SStrokerAce's Avatar
The head/cam package is designed for a 3.73 or higher gear with a 3500 or bigger stall in a A4 setup.
If you want a cam to work for N2O or Boost make sure you tell Lloyd so the proper changes can be made to the camshaft.
Bret
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Firechicken350
Jun 6, 2015 11:25 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Hyperspeed97z28
Aug 21, 2003 12:23 PM
NOMAD
N2O Tech
Jul 30, 2002 10:45 PM
