thermostats
Old Aug 15, 2006 | 05:24 PM
transAMdriv3r's Avatar
thermostats
well im getting a new water pump and i need to see what thermostats to get. i had one on my mind which is a "fail safe" thermostat, has anyone tried it? what are your thoughts? what would you recommend?..thanks for your help.
Old Aug 15, 2006 | 05:46 PM
Re: thermostats
Whatever t'stat you get, it MUST be specifically made for the "reverse cooled" LT1. A generic t'stat will not work correctly.
See Shoebox's tech pages:
http://shbox.com/1/tstat.jpg
Old Aug 15, 2006 | 07:18 PM
Re: thermostats
just orderd one, yeah it was made specific for the car. i think it is a good thing to have, it locks into the open position when it over heats if it should ever fail. the only thing is that, if it fails the engine will run cold cause it stays open.and the result will be horrible gas mileage. so ill know when it goes bad and ill be able to drive it home with no harm to replace it.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
