There may be a new lifter option
Old Feb 9, 2007 | 09:11 AM
Fastbird93's Avatar
Surprisingly, a search turned up nothing.
GM HD Lifters used in the Cadillac Racing Program -- these are designed similar to Morels with the lowered oiling hole, and are extremely durable. They're fairly new, but a lot of guys in the LSx world are already using them with great success. I'm trying to verify if they're a drop in assembly for the LTx motors right now, but given that the Comp R's and Morels are already the same PN used for LS and LT motors, I would presume that they are a direct swap.
Just throwing that out as there may be a reliable option than Comp R's for about half of the cost of Morels. I believe Scoggin Dickey has these for about $217 a set right now.
Old Feb 9, 2007 | 09:23 AM
MEAN LT1's Avatar
Ive heard about them but didnt knwo they were that cheap. That would be a way better option then spending 400+ on morels or Cranes oem's.
Old Feb 9, 2007 | 10:10 AM
2000GTP's Avatar
Exactly what I was thinking, if they are every bit as good as the Morels, then that is a pretty good deal.
Old Feb 9, 2007 | 10:11 AM
1SlowFormula's Avatar
Damn good find...
Subscribing to see the outcome but don't see why they wouldn't work considering I heard that the lifters are interchangable between LTx and LSx applications...
Old Feb 9, 2007 | 10:29 AM
buzz12586's Avatar
What about the comp cams high energy ones??
Old Feb 9, 2007 | 10:30 AM
Colin91Z's Avatar
Dang man nice find, hopefully this turns out to be the budget alternative to Morels
Old Feb 9, 2007 | 10:33 AM
Chris 96 WS6's Avatar
Good find indeed! I have a set of the newer Comp-R's I need to ditch.
Old Feb 9, 2007 | 11:34 AM
69gto96z's Avatar
My friend has a 96 Formula and we put a set of lifters in it from a 2000 Z28 with no problems at all, so I am sure they will work.
Old Feb 9, 2007 | 11:48 AM
seawolf06's Avatar
Just make sure to check your pushrod length if they fit. I'm guessing they will if they work in the LS1 motors, but they may be a different length which will change your geometry.
Old Feb 9, 2007 | 11:51 AM
mdacton's Avatar
I thought they were alot more expensive than that....I was thinking they were $500.00 you have a part # for ref.
Old Feb 9, 2007 | 12:08 PM
BLWNLT1's Avatar
Ditto..... get a part #
Old Feb 9, 2007 | 12:11 PM
speed_demon24's Avatar
I have them in my car, I paid $230 shipped from SDPC.
Old Feb 9, 2007 | 12:24 PM
Yeah? So, what's the part number, like people are asking?
Old Feb 9, 2007 | 12:25 PM
http://www.ls1tech.com/forums/showthread.php?t=580686
It's buried somewhere in there
Old Feb 9, 2007 | 12:29 PM
SStrokerAce's Avatar
GMPP 88958689 $220 a set
They do fit. They still need the spider in the lifter valvey which I hate but they do work.
These lifters have a ceramic internals rather than the steel parts to lighten them up. They should be more than enough for the limits of the stock ECU in terms of RPM. I had a good discussion with one of GM's racaing engineers about them, they are a pretty kick *** piece.
Bret
