Tach is off
Old 01-04-2005, 01:11 PM
ChrisUlrich's Avatar
Tach is off
My RPM tach is off... can that be fixed?
ChrisUlrich is offline
Old 01-04-2005, 01:14 PM
All4Chevy's Avatar
Re: Tach is off
Put it back on?
Bill
All4Chevy is offline
Old 01-04-2005, 01:29 PM
turbo_Z's Avatar
Re: Tach is off
Mine is about 200 rpm fast and it seems like most are that way. Thats not the problem is it?
turbo_Z is offline
Old 01-05-2005, 12:14 AM
Re: Tach is off
You might want to get a little more specific..... like how much is it off at what RPM?
Injuneer is offline
Old 01-05-2005, 12:21 AM
Z95m6's Avatar
Re: Tach is off
Ditto, they are all off about 200 rpms higher than actual. At least on the cars i've seen.
Z95m6 is offline
Old 01-10-2005, 01:12 PM
Re: Tach is off
Sorry about the delay...
Well I KNOW for sure that its off 150 at idle because Ion set it at 850 and it says 1000.
In 4th when I dynoed it shows I pulled off at 5450 when the teach read 5800.
And I think, according to the gear calculator... everything else is just off.
I redline 1st at about 43 or so? 2nd at about 62 or so? Forgot 3rd and 4th... I just think its really off.
Old 01-10-2005, 01:20 PM
Re: Tach is off
The numbers you quote seem "normal".... 150-200rpm high at idle is very common. And mine would indicate 6,000+rpm with the stock rev limiter, which was set at 5,886/5,805 rpm.
Injuneer is offline
mr28
04-20-2016 05:44 PM
Zee man
02-12-2015 07:07 AM
ldtantlinger92
01-19-2015 01:26 PM
mr28
11-23-2014 11:11 AM
Quick Reply: Tach is off
