Tach is off
My RPM tach is off... can that be fixed?
Re: Tach is off
Put it back on?
Bill |
Re: Tach is off
Mine is about 200 rpm fast and it seems like most are that way. Thats not the problem is it?
Re: Tach is off
You might want to get a little more specific..... like how much is it off at what RPM?
Re: Tach is off
Re: Tach is off
Sorry about the delay...
Well I KNOW for sure that its off 150 at idle because Ion set it at 850 and it says 1000. In 4th when I dynoed it shows I pulled off at 5450 when the teach read 5800. And I think, according to the gear calculator... everything else is just off. I redline 1st at about 43 or so? 2nd at about 62 or so? Forgot 3rd and 4th... I just think its really off. |
Re: Tach is off
The numbers you quote seem "normal".... 150-200rpm high at idle is very common. And mine would indicate 6,000+rpm with the stock rev limiter, which was set at 5,886/5,805 rpm.
