Tach help after the swap
Old Feb 11, 2015 | 07:04 PM
Zee man's Avatar
A while ago I swapped a 98 ls1 into my 94 z 28. The factory Tach doesn't read correctly, it looks to be @ 50% or so. I know this is a common problem with swaps, is there a fix for it?
I believe my tach is only seeing .5 of the ignition pulses. Not real sure about how to proceed. Any help is appreciated.
Old Feb 12, 2015 | 07:07 AM
Re: Tach help after the swap
Mismatch between the LT1 PCM tach output signal and the LS1 PCM tach output signal. I believe this ("tach signal") can be changed in the LS1 PCM with HP Tuners.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
