Swapped harnesses.....no communication with scanner.
Old Apr 19, 2005 | 09:13 PM
stockLT1's Avatar
I recently put a 96' harness and a 94' PCM in my car. Got a tune put on it (by using another 94' car) because my data port underneath the dash wouldn't communicate with the pcm. The car runs fine, but I have no way to access SES codes.
I had to switch a few pins in some of the connectors to make it run, but I have no ALDL port. Anyone ever done this or know what pins to switch etc. to make it work?
Thanks in advance...
Old Apr 20, 2005 | 09:29 PM
stockLT1's Avatar
Re: Swapped harnesses.....no communication with scanner.
Anyone??
Old Apr 20, 2005 | 09:43 PM
You can see what pins are what on the DLC here.
Though this shows the PCM to 16 pin 1995 DLC connections, you can correlate them to the 12 pin DLC. 1994 and 1995 PCMs are pinned out the same.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
