Summer Time is here and Need to keep engine cooler!
Hey guys,
You all know that when the temp get high we lose a big chunk of power that is definetely noticeable.
I would Like to keep my car at the lowest possible tmeperature.
I have a 160 hypertech thermo
What else can I do? I want the cooolest possible solution.
What are my options? What I have in mind are
Fan Switch
Watter Wetter for the Coolant/Radiator
I would like to do anything possible to keep it as low as can be. What do you think?
Fan Switch
Get the fans programmed to come on sooner, tranny cooler if it's an A4 (want that to last too, right?), drain and fill with new coolant/water. A couple of bottles of Water Wetter wouldn't hurt either..
Hey silver, I heard that If you have no coolant then its bad for the engine. But if it wont cuase any harm, then i guess I can add only water and redline. Whats the pros and cons of this?
Originally posted by Z95m6
You could just get some heads and a big cam then you wouldn't be worried about losing a few hp from the heat.
Originally posted by Silver
Distilled water, NO coolant and a bottle of Redline. Knocked 10-15 deg off my stock '95. Whoever started calling antifreeze "coolant" gets an adrenaline rush from winding his Civic to 7k.
My car runs cooler and the water and radiator stays clean. This is fact, not rumor that's been twisted by post after post.
Straight tapwater can and will rust and corrode your radiator. That's the other advantage of the Redline - you need SOMETHING to fight corrosion and lube the water pump slightly... I'll give you three guesses what the distillation process is used for...
Some of you guys really shouldn't spread ignorant rumors. We've got enough to last as long as any of us will ever be around.
Distilled water is simply pure H2O. It is as pure H2O as you can get, free of any other chemicals or impurities.
As for running without coolant, most coolant has some anti-corrosive additives in it which keep anything from rusting and also helps to keep your water pump lubed. Running without coolant is a bad idea.
I would at least put some in with your H2O, unless you are running about 50/50 mix of the redline.
You can save the $70 and wire your fan switch yourself. I don't remember where the link is for it, but you can save some money that way. My fans are always on in summer unless I'm getting on the x-way for a while, then I shut them off, they aren't really needed on the x-way. Temp never makes it to halfway, I need a 160 thermo, might keep it a little lower.
I would at least put some in with your H2O, unless you are running about 50/50 mix of the redline.You can save the $70 and wire your fan switch yourself. I don't remember where the link is for it, but you can save some money that way. My fans are always on in summer unless I'm getting on the x-way for a while, then I shut them off, they aren't really needed on the x-way. Temp never makes it to halfway, I need a 160 thermo, might keep it a little lower.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
