suggestions on changing oil pan gasket
Old May 23, 2004 | 03:44 PM
meangrn94ta's Avatar
i was checking to see if the timing chain was at TDC ( cause of the high rpm miss i have) and i guess i tore the pan gasket. what is the best way to go about changing the pan gasket of motor is still in the car
Old May 23, 2004 | 03:54 PM
gb95zconv's Avatar
Ive not done it myself but Ive read a few threads where the gasket was stretched over the outside of the pan and worked over the lip into place. Do a search and you may find the threads.
Old May 23, 2004 | 04:00 PM
12SCNDZ's Avatar
Remove the motor mount bolts and jack the engine up about 3". Remember to remove the oil level sender from the pan before you curse it for not coming down!...LOL The sensor lays above the windage tray, so the pan won't come off with it in. After you jack the engine up, it's not a real big deal. I used an engine hoist to lift the engine from the top, but I suppose you could use a floor jack under the damper to accomplish the same thing.
Frank
Old May 23, 2004 | 04:08 PM
ok but where is the windage tray and where is the damper. i prolly know what they are but just not by the reall name. more like that dohicky something of that nature. lol
Old May 23, 2004 | 04:23 PM
12SCNDZ's Avatar
The windage tray is bolted to your main cap bolts...You don't have to worry about it. Just make sure you take the oil level sender out first.
The damper is the correct name for the "harmonic balancer"...Or, on our cars the bottom pulley.
Frank
Old May 23, 2004 | 05:15 PM
thanks alot guys after i took the oil level sensor out the pan drop a little more and i did the scretch the gasket method. it work great thanks to help of my wife and her little hands and your suggestions.
mike
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
