Suggestion on changing springs
Old Apr 11, 2008 | 08:23 AM
95Blackhawk's Avatar
Hi all,
I am building a 383 and am concerned about the springs on the heads I bought. They are CC 978's with Ti retainers and with a confirmed seat pressure of 130 lb and no coil bind on the very aggressive cam lobes I will use.
The rest of the valvetrain is as follows:
LS7 lifters
hardened pushrods
guide plates
CC pro mag 7/16 rockers
I want to rev to 6800. Knowing this, am I being cheap by not going with what the cam grinder suggests with the PAC-1218 or 1518's?
Thanks all
Ben
Old Apr 11, 2008 | 09:06 AM
96capricemgr's Avatar
Going to have to tell us what lobes otherwise we are just guessing.
Based on what you have offered though I think you need new springs, 130 on the seat in a double spring is not going to control much to 6800rpms. Well I guess it depends on your definition of control though. I have a sneaking suspicion you are using a cam grinder who tries to loft the lifters on street cars and "control" it by having the spring smash into coilbind. Not my definition of control but apparently is to some.
Old Apr 11, 2008 | 09:39 AM
I wish I could tell you about the lobes but knowing it is Bret Bauer will probably help. From my emails to him, he just gives an answer of "it it was me, this is what I would do" but wanted others to respond before I put out more money on this project.
Old Apr 11, 2008 | 10:36 AM
"if it was me".......... I would pick a different cam guy. That is the best advise anyone can give you at this point.
Old Apr 11, 2008 | 01:23 PM
ulakovic22's Avatar
I'm not going to say anything, but I have run Bret's cams and I've never had a problem. You will find more people that have good experiences with his cams than people with bad experiences. I'll update in a month or so after I run yet another one of his cams in hopefully what will be a 800+ hp monster.
Old Apr 13, 2008 | 06:21 PM
rpm4lalo's Avatar
I am spinning to 7000k with Pac 1518's.
Old Apr 27, 2008 | 08:03 PM
rskrause's Avatar
Moderator
Bret is usually on the money with valvetrain stuff.
Rich
Old May 5, 2008 | 12:35 AM
Steve in Seattle's Avatar
Rich
agreed.
Old May 5, 2008 | 11:25 AM
cehan's Avatar
You can put me in the "happy with Bret's cam" column too
Old May 5, 2008 | 01:42 PM
krillformula's Avatar
yea me2!
meissen
Jun 1, 2015 07:59 AM
alex5366
Feb 17, 2015 08:12 PM
Don 97 SS
Jul 11, 2005 08:50 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
