Stupid plug wire question.....
Old Nov 20, 2005 | 06:39 PM
wrd1972's Avatar
Doing the OVC plug wire kit from elitesparkplugs.com
I have one wire that absolutely must touch a header. The plugs have the heat wraps.
Does this mean it wont burn up?
I may be able to order a single wire with a straight boot, this may fix the problem too.
Is there somthing I can put over the wire so it can sit against the header?
Old Nov 20, 2005 | 07:57 PM
firebirdStud's Avatar
Re: Stupid plug wire question.....
do Not let it touch the header no matter what. What kind of headers are you using? There is absolutely to way to make it work? You bought the wrong headers then! sorry. But, what headers are you using right now?
Old Nov 20, 2005 | 08:07 PM
If it is on a header pipe, count on it burning.
Old Nov 21, 2005 | 12:19 AM
2000GTP's Avatar
Even with the heat protection sleeves, the wires will still melt.. trust me I know from past experience
Old Nov 21, 2005 | 07:12 AM
wrd1972's Avatar
Nuff said. I have the RK sport headers which are the same as the Arizona speed & marine. Its that horizontal primary that mkes it hard to work with the #6 plug wire. I am going to order a custom wire with a straight boot instead of the 90 degree boot. I think that will help me out.
Old Nov 21, 2005 | 09:22 AM
I have RK Sport headers, and I hate them. They are the reason I dont have otvc wires yet. You absolutely can't sneak wires through there. Well, at least on mine there is no chance in hell. But, good luck to you. FYI I am swappin out my rk sports with pacesetter longtubes, so I can run otvc wires, and pick up some more torque with my stroker.
~Cody
Old Nov 21, 2005 | 02:48 PM
wrd1972's Avatar
My OVC work perfectly for all cylinders but #6. I just ordered a custom wire with a straight boot that will fix the problem.
You can sneak the rest of them in without any problems.
Are you going to sell your RK's and if so how much.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
