Strong fuel smell...
Old Nov 14, 2011 | 08:38 PM
Myxtreme1's Avatar
On my '94 (all stock) I keep getting a strong gasoline smell while driving. At first I though it was just under strong acceleration but it seems to at normal driving too. I am very "intimate" with these cars and I can't seem to find any leaks anywhere. I haven't checked cue pressure but intend to. This car it somewhat had to start , having to turn over a few times before firing. Any ideas?
Old Nov 14, 2011 | 10:21 PM
JGuy07's Avatar
Re: Strong fuel smell...
Like you said, checking fuel pressure would be a good idea. Could be leaky injectors and it could be running rich causing the smell. No codes?
Old Nov 14, 2011 | 10:51 PM
nintythreeZ28's Avatar
only because you did not state when you filled up i will be the first to say DO NOT OVERFILL THESE CARS! I think im the only idiot who made that mistake
Old Nov 15, 2011 | 01:07 AM
JackBlack95's Avatar
Possible gas cap?
Old Nov 15, 2011 | 04:44 AM
bw_hunter's Avatar
Quite possibly the charcoal canister for the evap system. The canister is located in the DS rear wheel well. Sniff around there.....
Old Nov 15, 2011 | 07:15 AM
Myxtreme1's Avatar
Thanks for the replies. I will check that stuff.
Old Nov 15, 2011 | 04:06 PM
lt1cruzin's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=839639
Old Nov 15, 2011 | 04:52 PM
2QUIK6's Avatar
Ummm. What exactly happens when you overfill? Had mine more than 15 years and have not observed any issues occasionally topping it off and gas pouring out of filler neck being full.
Old Nov 15, 2011 | 05:18 PM
Most of the cars I've seen with stinky fuel smell entering the passenger compartment were the result of the vent line on top of the tank cracking. That's the line that goes to the EVAP canister.
See Shoebox's diagram:
http://shbox.com/1/evap_system.jpg
HarleyZ28
Oct 5, 2015 06:23 AM
TitoPR221
May 26, 2015 12:20 AM
ChrisFrez
Mar 1, 2015 01:33 PM
cmyname1
Feb 19, 2015 08:38 PM
ChrisFrez
Feb 1, 2015 08:26 AM
