94 z28 lt1 problems
Old Nov 14, 2011 | 11:03 PM
twistedbowtie's Avatar
94 z28 lt1 problems
hey guys i have just bought a 94 z28. it has a bad exhaust valve, leaking timing cover, possible bad opti, needs new front hub due to wear from front seal, also the 4l60e is very weak so im planning to pull the tranny soon. i recently droped the motor from the bottom on my 95 z28 and its not hard but just a pain in the a** with out a lift. i have longtube headers, cc306 cam,new opti, stock heads will small port work and PAC racing springs.
if i decide not to pull the motor how hard it is todo a cam swap with the motor in the car?
Old Nov 14, 2011 | 11:14 PM
Re: 94 z28 lt1 problems
You probably already know all the steps to doing a cam swap, but there is just less room.
http://shbox.com/ci/cam_removal.html
Old Nov 14, 2011 | 11:35 PM
thanks man, but if i remove the radiator i should have plenty of room to get the cam in the front right?
Old Nov 15, 2011 | 01:05 AM
JackBlack95's Avatar
I think there is an article in this months GM high performance magazine.
Old Nov 15, 2011 | 04:48 AM
bw_hunter's Avatar
You should, yes. If you don't it's just because you have worn motor mounts....a jack under the oil pan will give you the extra you need. Just be careful not to crush the pan.
Old Nov 15, 2011 | 06:36 AM
If you looked at the link, you also have to move the a/c condenser out of the way.
Old Nov 15, 2011 | 07:13 PM
alright guys im planing to put in new motor mounts when i install the headers to keep the floor vibration away.
thanks for all the the help ill keep in touch as the process continues
Noenav
Mar 1, 2019 07:38 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
Absolute Z28
Jul 19, 2002 02:21 PM
