Stripped oil pan drain plug
Old Jan 25, 2004 | 07:16 PM
Waitin4aSS's Avatar
My drain plug on my oil pan is starting to get stripped. What can I do to fix the problem? Is there maybe like a rubber plug i can put in to prevent a future leak?
Old Jan 25, 2004 | 07:21 PM
AsianSensation's Avatar
I bought a new one. Only a few bucks.
Old Jan 25, 2004 | 08:32 PM
AdamZ1LE28's Avatar
Yeah they're available at any local parts store for like $5, just be sure it has a new gasket on it or it will leak like a bastard....
Old Jan 26, 2004 | 08:42 AM
QUASARBLUEZ28's Avatar
Just a thought here. If your drain plug is stripped then whats the codition of the threads on the oil pan? I think I would chase the threads on the oil pan before installing the new plug.
Old Jan 26, 2004 | 08:49 AM
Robbie's Avatar
Change your plug out and if you find out your pan threads are stripped as well just get a self tapping plug to put in.
Old Jan 26, 2004 | 10:29 AM
Ace_437's Avatar
Are you sure there are even threads in the pan? I've never had an oil pan off, but I never thought there were really threads in it, just the plug. Maybe I'm and idiot.
Old Jan 26, 2004 | 10:35 AM
If it "screws in" it needs threads. There is a metal reinforcing plate tack welded behind the pan sheet metal that has the threads. Yes, it is possible to strip the threads in the pan. In that case, you by an "oversize" self-threading plug.
Old Jan 26, 2004 | 10:56 AM
Robert95z's Avatar
There are many universal drain plugs out there... Maybe you should just go to a 10min oil change place, pay for the oil change and ask them to put a universal plug on it
Old Jan 26, 2004 | 11:09 AM
Waitin4aSS's Avatar
Sorry guys I didnt explain well enough. The threads in the pan itself are getting stripped not necessarily the bolt. So could I buy a selp tapping plug or a universal plug at an auto parts store?
Old Jan 28, 2004 | 07:24 PM
Robbie's Avatar
Im sure you can. Although i've never looked. We've used alot at my work. They work fine.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
