stripped distributor gear
Old May 30, 2008 | 05:27 PM
Burning Rubber's Avatar
Anyone ever stripped a distributor gear?? If you have do you have any idea what caused it to strip? I have stripped two gears off and I have had two different motors and had the same problem in both motors. There are only a few things in the motor now that are the same as the first motor. The cam, the lifters and the retainer plate and the timing gears. all of which have about 7,000 miles on them. Any help would be greatly appreciated.
Old May 30, 2008 | 05:33 PM
The Engineer's Avatar
An LTX engine (factory Opti) "does not" use a gear-drive, the Opti distributor is direct-coupled to the cam shaft.
WD
Old May 30, 2008 | 06:00 PM
when i say distributor gear i mean the oil pump drive gear in the back of the valley under the intake manifold.
Old May 30, 2008 | 06:05 PM
mdenz3's Avatar
What cam are you using? Some require different oil pump drive gears.
maverickmk's Avatar
a high volume oil pump will cause the pump drive to wear out prematurely, also, mismatched materials in the cam and the drive will lead to failure
Old May 30, 2008 | 07:30 PM
i have a CC306 camshaft and I had a HV pump in my old motor but now i have a stock pump. Where can I get a gear made from different material?? And what kind of material should I use I street drive the car a lot.
Old May 30, 2008 | 08:47 PM
maverickmk's Avatar
you need a stock pump drive - pn 1103868 - it's $44.38 at http://www.gmpartsdirect.com/catalog/frameset.cfm
Old May 31, 2008 | 09:40 AM
i Have a stock pump drive i got it from the dealership a couple months ago
Old May 31, 2008 | 10:02 AM
tireburnin's Avatar
Sent you a PM on the other board
DirtyDaveW
Dec 1, 2016 05:37 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Collector Car
Dec 17, 2014 01:12 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
