stripped distributor gear
Anyone ever stripped a distributor gear?? If you have do you have any idea what caused it to strip? I have stripped two gears off and I have had two different motors and had the same problem in both motors. There are only a few things in the motor now that are the same as the first motor. The cam, the lifters and the retainer plate and the timing gears. all of which have about 7,000 miles on them. Any help would be greatly appreciated.
i have a CC306 camshaft and I had a HV pump in my old motor but now i have a stock pump. Where can I get a gear made from different material?? And what kind of material should I use I street drive the car a lot.
you need a stock pump drive - pn 1103868 - it's $44.38 at http://www.gmpartsdirect.com/catalog/frameset.cfm
stockssn2o
May 25, 2015 08:54 AM
