H/C HR Cars Pushrod Length Poll
Old May 31, 2008 | 11:10 AM
truedualws6's Avatar
For you H/C hydraulic roller folks with setups that include rocker studs (no shaft mounts) and longer that stock valves I'd like to know what length pushrods you are using. Additional information to include in your post (if you know it) should be the amount of milling on the heads, head gasket thickness, location of valve tip contact pattern (center, offset I, or offset E), length of valves, and number of turns on the polylocks (total, not lifter preload). And if you've got it, put up a picture of the contact pattern.
My info is as follows:
> 7.30" pushrods
> .020" milling on heads
> .029" (Impala) head gaskets
> offset towards exhaust
> +.10 over stock length valves (I think)
> 8 turns on polylocks
And here is a picture of the swipe comparison between 7.05" and 7.30" pushrods. Sorry about the crappy pic for the 7.30" but that's all I have.
Old May 31, 2008 | 11:26 AM
user 647483's Avatar
> 7.15" pushrods
> .010" milling on heads
> .026" (Mr Gasket) head gaskets
> zero-decked (That's about .030" below stock, seems important to this discussion)
> never looked at the offset
> stock length valves
> Do not rememeber rhe number of turns on polylocks
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
$hawn
Aug 28, 2002 09:09 AM
