Steering shaft is rubbing only when turning right
Old Jun 1, 2007 | 07:43 AM
  #16
shock6906's Avatar
There's two upside down U shaped pieces of metal on my steering shaft that were interfering with my header. I just took a big pry bar and beat them in towards the shaft. No more problems.
Old Jun 1, 2007 | 08:05 AM
  #17
always faster's Avatar
Already done it .It seems to rub from the upper knuckle part.
Old Jun 1, 2007 | 10:19 AM
  #18
2QUIK6's Avatar
Originally Posted by always faster
I got Kooks headers and there is no way in the world that i would dent/hammer/crush or scratch those quality pieces
My Kooks hit big time..if they were quality pieces they wouldn't rub Really pisses you off to pay that much and then fitment is an issue ay.
I ended up having to dent them in They would clear when cool, but once up to op temp they would rub very hard. I shaved the knuckle, adjusted the knuckle and moved the column as much as possible.
Old Jun 1, 2007 | 10:34 AM
  #19
Im not that much disapointed because each car has its own problem.The fittement is perfect for everything else except the steering linkage.In normal driving even when they are hot its not rubbing.It only rub when i turn to the right with a little bit of throttle.Alot of people would accept this little disagreament but not me
I ve tried to move the steering column but it barely move so this option is dead.
I also tried to shave it more but my dremel let me down and die...
I will try a ls1 steering shaft to see if it fit better.
Old Jun 1, 2007 | 03:49 PM
  #20
1racerdude's Avatar
The LS1 shaft has NO rag joint.
Old Jun 1, 2007 | 07:19 PM
  #21
Bud M's Avatar
Good call, that should only be done as a last resort.
Old Jun 2, 2007 | 05:30 AM
  #22
Yeah i know now but are they smaller in size or they are the same?
Old Jun 2, 2007 | 07:31 AM
  #23
joeSS97's Avatar
www.unbalancedengineering.com
Old Jun 2, 2007 | 08:00 AM
  #24
Originally Posted by joeSS97
Yup i already check this after your reply in the "wanted" section but a steering shaft is cheaper and also smaller.
Victor Lamb
Aug 26, 2017 02:52 PM
CaRParts102
Dec 6, 2014 08:45 AM
squarehead
Nov 21, 2014 08:02 PM
formula79
26
Aug 5, 2002 12:21 PM
