Steering shaft is rubbing only when turning right
Old May 31, 2007 | 09:21 AM
always faster's Avatar
Ok i know first ovall i ve used the search fonction a made a couple of modification on my steering shaft:
-I cut the half of the top bolt head that hold the top part of the linkage(near firewall)
-I cut the exceeding part of this bolt on the other side of the linkake
-I connect the linkage has far away has possible of the firewall to create some space
-I begin to shave it but not really much
Now everythings clear except when i turn right with a little throttle.By the way i got brand new poly motor mount.
What are my possibility:
-Shave the linkage again.But im affraid to weaken it...So how much can be taken.
-Is it possible to move the steering column maybe 3/8" toward the the driver side of the car.Or maybe 3/8" lower?
Thank you
Old May 31, 2007 | 09:22 AM
1racerdude's Avatar
Get a shaft that fits a LS1 car.
Old May 31, 2007 | 09:23 AM
Can i ask why?
Old May 31, 2007 | 09:35 AM
1racerdude's Avatar
Originally Posted by always faster
Can i ask why?
They are of a different design. They are smaller and will probably clear.
Old May 31, 2007 | 09:39 AM
Since i love the search fonction i ve search for it and people tend to have a problem with the steering wheel alignement,causing the steering to no be straigth when the wheel are straigth.
Is it true?Because i dont wanna have my wheel straigth and my steering wheel pointing left or right just like if i was turning
Old May 31, 2007 | 09:44 AM
1racerdude's Avatar
That is cured with a front end alignment.
Old May 31, 2007 | 09:48 AM
Ok i just put install it and bring my car to the alignement shop.
Thats good now i need to find one
Old May 31, 2007 | 09:53 AM
1racerdude's Avatar
Junk yard or look on the board for someone parting out a car.
Old May 31, 2007 | 12:41 PM
speed_demon24's Avatar
You're sure your rack isn't loose since it only does it when you turn right?
Old May 31, 2007 | 12:52 PM
BUBBA's Avatar
Just make 3 left turns.
Old May 31, 2007 | 12:55 PM
Just out of curiosity, what is the steering shaft rubbing on? I couldn't find that in your original post. I could take a WAG and say its hitting your headers, but why guess?
Old May 31, 2007 | 02:00 PM
ashakeandfrys's Avatar
loosen the three bolts that secure the steering column to the firewall and have a buddy nudge the shaft with a prybar.. gave me 1/4 of an inch.
Old May 31, 2007 | 02:34 PM
Yeah the knuckle of the steering shaft is rubbing on my headers
Old May 31, 2007 | 05:33 PM
bdc95ta's Avatar
Shave it more it will be fine. If you don't feel comfortable with that dent the headers.
Old Jun 1, 2007 | 07:09 AM
First i would like to say that the next comment is not a bashing one ok
If my headers would have been some basic pacesetter i would have probably dent it.
but...
I got Kooks headers and there is no way in the world that i would dent/hammer/crush or scratch those quality pieces
