Steel versus aluminum rocker arms...Pros and cons?
Old Apr 28, 2004 | 09:24 PM
RamAir95TA's Avatar
I picked up a set of new Crane golds, but it seems like I've been stumbling across some bad news on not just the Cranes, but aluminum-bodied rockers altogether.
Do aluminum rockers deflect more than steel rockers? What is the BIG difference that would make someone pick a steel rocker over an aluminum?
Need a little help...if the majority says to use a steel rocker, then I need to send the Crane Golds back. Thanks in advance.
~Joe
Old Apr 28, 2004 | 09:29 PM
Spinner's Avatar
Steel wont wear like aluminum (stress cycles) and eventually break.
Old Apr 28, 2004 | 09:50 PM
GreenDemon's Avatar
I read about that too. It has to do with how the metal reacts to force. The steel stays rigid all the way to a certain point, then it starts to bend. The aluminum starts bending at a much lower level. So the aluminum is always flexing to a small extent, whereas the steel stays rigid.
I don't think the deflection would have anything to do with lift #s or valve float, etc, just the reliability of the rocker. The only pro to aluminum would have to be the lighter weight I would think.
Unless someone can say something else good about the aluminum rockers over steel I would always choose Comp's pro mags...
Old Apr 28, 2004 | 09:51 PM
Eddie95Z28's Avatar
I guess the pros of Aluminum is that they are lighter... but the Steel pro-mags are lighter over the nose and stronger... I myself went with the pro-mags because they are rebuildable and warrantied forever if the bodies break.
Old Apr 28, 2004 | 09:55 PM
rskrause's Avatar
Moderator
I like aluminum for a hydraulic cam. With the relatively light springs used with a hydraulic cam, they are plenty stong enough. Longevity with these springs should be fine too. GM used them on the LT4, right? For a solid lifter cam and race level spring pressure I would go with a steel rocker though.
Rich Krause
Old Apr 28, 2004 | 10:02 PM
Serene's Avatar
steel is what i would go with. most of the mass is concentrated on the pivot point of the rocker
Old Apr 28, 2004 | 11:16 PM
97WS6SCharged's Avatar
Pro mags all the way.
Old Apr 29, 2004 | 04:57 AM
RamAir95TA's Avatar
I'll be using one of the larger (236/242) XE grinds from Comp. Should I send the Crane Golds back and pick up the Pro Magnums, or will I be ok with them? I won't put many miles on the car once it is done, and will probably be a weekend/strip car.
Any more thoughts? Thanks.
Old Apr 29, 2004 | 05:07 AM
simple's Avatar
ProMags are rebuildable by Comp, thats one of a few very good qualities about them
Old Apr 29, 2004 | 06:45 AM
rskrause's Avatar
Moderator
I wouldn't hesitate to use them. But if it will make you feel better, get the Pro-Mags. As I said previously, I have used both with no problems and would only say that if you are running a spring with >300-350lbs over the nose that you should stick with a steel rocker if you plan to get a lot of miles out of them. Of course, cars with >300-350lbs tend not to see many miles between rebuilds anyway
Rich
Old Apr 29, 2004 | 07:13 PM
Josh-'04 GTO's Avatar
Comp Pro Mags are 8650 chromemoly steel, which is THREE times stronger than the 7075 aluminum used in Crane's. It's not even a contest.
If you're talking about stamped steel rockers, then you're absolutely right about them breaking.
HarleyZ28
Oct 5, 2015 06:23 AM
2QUIK6
Jul 15, 2015 07:46 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Mar 7, 2015 09:21 AM
