starters
Old Nov 24, 2008 | 01:11 PM
z28camaro1090's Avatar
starters
i went to put a new starter in my 93 and it had a 95 starter ... are the 2 interchangable or does that mean at some point the guy before me put a 95-97 motor in it?
Old Nov 24, 2008 | 02:19 PM
Jazsun's Avatar
ummm how do you know the starter is a 95? All LT1's should be the same... I think???? I have an LT4
Old Nov 24, 2008 | 02:25 PM
seawolf06's Avatar
All LT1 starters are the same. I'd be surprised if there was a real difference for the LT4.
Old Nov 24, 2008 | 04:14 PM
Be surprised, then. LT4 starters are different (though, interchangeable).
Old Nov 24, 2008 | 04:16 PM
seawolf06's Avatar
What makes them different?
Old Nov 24, 2008 | 06:59 PM
flyinZ's Avatar
They are lighter, smaller in size(i think) and I think the ratio is different..
Old Nov 24, 2008 | 11:21 PM
thats what was confusing this one was much smaller.. and the guy i bought the car from didnt know to much about it because he bought it from his cousin. is it possible he has a lt4 in it. i know it was suppose to be stock besides the mods i listed.. and i ran with a 06 GTO and he got me by like 4-5 inches max.. in a about 1/4 mile stretch... how would i tell a lt4 from lt1?
Old Nov 25, 2008 | 08:41 AM
seawolf06's Avatar
Something must have been wrong with the GTO or that driver.
You can look at the head, intake or block casting numbers to see if they are LT4. Other than that you can take off the pan to see if you have a 4 bolt main.
Old Nov 25, 2008 | 09:24 AM
Jazsun's Avatar
The size is about the same but they are stronger than an lt1, i literly cracked my lt1 starter in half, no problem w/ the lt4, it cranks stronger and is physically built better. It also makes that sweet high pitched wine when you start your car.
Old Nov 25, 2008 | 11:51 AM
That Camaro Guy's Avatar
Is the LT4 starter the same gear reduction starter that was put in the vettes? When I needed a new starter a few years ago for my Z I just went to the parts store and asked for a starter for a vette for the same year. It was a gear reduction starter and bolted directly up and worked 10x better then the direct drive hunk of junk that came with the car.
Old Nov 26, 2008 | 12:04 AM
yeah im not sure what was up when i raced the gto. it was a auto so not real hard just step on it.. but i can almost hear a mild cam i gotta figure out what else is inside my motor
Old Nov 26, 2008 | 05:21 AM
There is no "LT4 block", and being a 4-bolt block does not identify it as an "LT4" block. Used the same 4-bolt main block that was used in the Corvettes and all factory warranty replacement engines, including F-Bodys. Same part number was used on both the 2-bolt and 4-bolt blocks.
Originally Posted by That Camaro Guy
Is the LT4 starter the same gear reduction starter that was put in the vettes?.
Yes, it was specific to the 1996 LT4 Y-body engines.... that's why its called the LT4 starter.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
