Started pulling my motor today, what can i get rid of?
All you need to do is remove the compressor, and replace it with the 1LE "AC delete" pulley assembly. In most cases, the stock belt works, if not, its about a 1/2" difference.
If you leave the heater coil and fan intact, your system will continue to blow hot air for heat and defrost. Defrost will not be as efficient, because it normally runs the AC to knock the moisture out of the air, then reheats it with the heater coil.
I appreciate the info Fred, probably a repetitious question, but is that AC delete pulley hard to find? My air doesn't work anyways, and likely I'm going to be running a '93 car I recently picked up in April's shootout, cam, spray & converter.
My 95 is still down and out, unfortunately. Thanks again.
Darth Xed
13
Jul 22, 2002 12:45 PM
