Started pulling my motor today, what can i get rid of?
Old Nov 12, 2007 | 09:56 PM
jclark311's Avatar
Do you think they could have a few more vacuum hoses, and wires? My God, what can i get rid of? I am putting race longtubes so i wont need the air pump.
Old Nov 13, 2007 | 12:17 AM
urbaNHunter44's Avatar
haha yeah alot of crap on it huh.
You can loose the air pump and egr, along with their associated vacuum lines for starters
Old Nov 13, 2007 | 05:58 AM
2000GTP's Avatar
You could delete the A/C as well, that will shed some pounds.
Old Nov 13, 2007 | 07:09 AM
rickjames343's Avatar
I just put race longtubes on the other week and got rid of the EGR and AIR. I dont think i did much else
Old Nov 13, 2007 | 02:55 PM
1racerdude's Avatar
Make sure ya TAG all those hoses and wire or it will be a mess to go back with.
Or you have a schematic.
Ya think ya got trouble now,wait a while.
Old Nov 13, 2007 | 03:31 PM
93transam1234's Avatar
your not pulling the whole motor just to LT's on are you?
Thier is a ton of stuff you can get rid of, ABS stuf, A/C, EGR, Air, you could even go carbed and get rid of almost all the wires ... How much do you want to get rid of/spend? Are you trying to make a track only car?
Old Nov 13, 2007 | 07:46 PM
jclark311's Avatar
Nah putting in a new motor.
Old Nov 13, 2007 | 08:34 PM
danhr's Avatar
air pump, air pump bracket, egr valve, abs block, a/c compressor, a/c canister, a/c condensor, power steering (for the really hard core), cruise control computer, front bumper support if you really wanted to, front sway bar,
that's all i can think of right now
Old Nov 13, 2007 | 10:15 PM
userchemical's Avatar
BEFORE
Air pump, egr, ac and all supporting pipes. re-routed spark plug wires.
and if you have ABS and wanna clean it up even more, remove that aswell.
Old Nov 14, 2007 | 10:00 AM
Then, there's fuel supply lines to the back of the rails, no IC Module, no wires to the Opti, no MAF, no cruise cable, and no dirt.... ........
http://www.injuneer.com/images/photo.../DCP04257a.jpg
http://www.injuneer.com/images/photo.../DCP04255a.jpg
Old Nov 14, 2007 | 10:12 AM
VK's Avatar
VK
Last thing i dumped was the ABS, i was missing the speed ring on the carrier anyways. The big things that i noticed that helped was dumping the AC, the AIR pump then the ABS.. EGR and other emission goodies are gone but didn't clean things up as well as others.
I also removed the horn (intercooler piping), relocated the cruise control, removed and re-did some wiring.
Guess i need to learn when to stop
Old Nov 14, 2007 | 10:54 AM
ZL1modified's Avatar
i like the "no dirt" comment.
Did you ever think about loosing that box that the ac lines go into?
thats how mine looks and i'd like to get rid of it but i'm not sure how...
Old Nov 14, 2007 | 11:26 AM
R&D Speed's Avatar
Everything you need to remove the EGR/AIR system can be found on our site:
http://www.rdspeed.com/category.sc?categoryId=4
Old Nov 14, 2007 | 11:41 AM
Hotwire's Avatar
#1, you've obviously never had to mess around with a 70s/80s vehicle have you? You have no idea.
#2, try throwing the motor into something different, you get to learn every single wire in the wiring harness, coolant flow, etc. I love em!!
I personally wouldn't remove the ABS, A/C, or power steering. For the small amount of weight you save, you gain a lot more frustration w/ custom pieces and no creature comforts. I wouldn't touch the safety items either. Removing the ABS is just about equal to taking the seat belts out. It also helps resale value to know everything hasn't been jury rigged or focked with.
Good luck!
Old Nov 14, 2007 | 01:49 PM
danhr's Avatar
you need to either fabricate your own hvac delete plate or buy one
