Stall w/ LT4 Hot Cam?
Old May 13, 2004 | 02:36 PM
ArizonaZ's Avatar
Is a stall converter necessary when putting in the LT4 Hot Cam kit (not heads and intake, just cam springs, rockers, etc). Also, what else would you need to get, i.e., tune, headers, etc?
I am really interested in doing this over the summer, but want to get everything to do it right. Already planning on putting in 3.73's and some suspension mods.
I know that there are bigger cams out there, but I am really looking for street realiablility and drivability, among other things.
Old May 13, 2004 | 02:47 PM
FacelessZ's Avatar
It would certainly cut your 1/4 down ~.5 seconds. With a curve like the LT4 hotcam gives, I'd say go with a 2800-3000 stall converter and of course a transmission cooler and a tune...
Old May 15, 2004 | 08:31 AM
94DROPTOPZ28's Avatar
I have a Vigilante 3200 converter & I'm VERY happy with the results with my Hotcam kit...
Old May 16, 2004 | 09:56 AM
formula383's Avatar
Definitely get a converter, I have the Vigilante 3200 and that is what I would suggest.
Old May 16, 2004 | 10:12 AM
FastZinTennessee's Avatar
I think you'll be ok on the stock converter if you need to drive around like that while you save money. From driving my car around with the converter locked up with the HOTcam, I can tell it still has plenty of low end. That's with some home ported heads too. I have a Midwest 2800 converter, and it works well.
Old May 16, 2004 | 12:30 PM
CMGETSM's Avatar
Do the verter and the headers before the cam. A torque converter, shift kit,and tranny cooler should be the first upgrade for an A4 car. IMO.
Old Jun 2, 2004 | 11:37 AM
Hotwire's Avatar
when i was doing the lt4 conversion i looked around and did a lot of research. i called TCI direct and talked w/ their tech support. my truck weighed 3600 lbs w/ me in it, they suggested a 3200 stall, so these guys are right.
I ended up going w/ a TCI super street fighter 3500 stall from www.texas-speed.com, got it in a group purchase for $443 right to my door. I loved it.. was a little over the top for the combo, but it was a fun little truck.. till i had to sell it.
Old Jun 2, 2004 | 12:06 PM
Brandon94Z28's Avatar
I had a 2400 slp stall with hot cam and all the bolt-ons. Car trapped at 110mph and was just as streetable as stock.
good luck
Brandon
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
