speed den to maf
Old May 29, 2007 | 02:51 PM
93camarochrisz28's Avatar
speed den to maf
can it be done and is it hard to change everything over ??
Old May 29, 2007 | 02:52 PM
Mortify's Avatar
I would not see the point, there would be no to minimal power gain from switching..
Old May 29, 2007 | 03:09 PM
96ZCamaro's Avatar
I personaly would not go through the trouble of doing it. But the one way I can think of doing it would be to get a wireing harness and computer out of a MAF camaro/trans am.
Old May 29, 2007 | 03:41 PM
well if there is no plus side to it then i dont think i am gonna waste my time thanks
Old May 29, 2007 | 04:09 PM
Mortify's Avatar
Yeah, you can still find good tunes for SD. might aswell stay unique compared to the (lame) 94+ F-bodies :P.
By the way, join SpeedDensity.org, site dedicated to SD cars.
Old May 29, 2007 | 04:11 PM
lol thanks for the info
Old May 29, 2007 | 05:57 PM
cloim's Avatar
I've noticed several people going in the opposite direction.
Specifically, tuning there cars with the MAF unplugged, then never bothering to plug it back in. (MAF defaults to speed-density if the sensor stops working).
It's been awhile since I read up on the pros and cons of each system. But I ended up coming to the conclusion that if I had the ability to tune the system, I wouldn't have any motivation to switch to anything else.
One possible exception is forced induction. But my memory is too foggy to recall why. And I wasn't dealing with an fbody back then.
Another is radically high-hp. And that would be a switch to alpha-n for a track-only car.
Old May 29, 2007 | 09:53 PM
evilundisguised's Avatar
Because a speed-density system is sensitive to manifold pressure, and the stock setup incorporates a 1bar MAP sensor (which maxes out at 0psi boost).
Old May 29, 2007 | 11:53 PM
neil350's Avatar
For simple set ups, you can get good mail order tunes.
DirtyDaveW
Dec 1, 2016 05:37 PM
3TAS4ME
Apr 15, 2015 02:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pete53
Dec 9, 2014 07:31 AM
Jul 4, 2005 05:00 PM
