speaking of pushrods
Old Jul 28, 2005 | 11:44 PM
simple's Avatar
at what point or reason would a longer then stock pushrod need too be used?
Old Jul 29, 2005 | 02:33 AM
sssalah's Avatar
Re: speaking of pushrods
When a small base circle cam is used or when taller valves are put in, also if a taller deck block is used, but thats not an option for an LT1. In any case if doing significant changes that would affect optimum pushrod length, it is a must to check the vavltrain geometry and rocker to valve contact with a pushrod checking tool. Then order the correct length pushrods.
Old Jul 29, 2005 | 07:26 AM
rskrause's Avatar
Moderator
Most common reason is swapping in a bigger (more lift) cam. Sounds bassackwards, but with most high lift cams the base circle radius is smaller rather than the nose being taller. Changing heads can also be a reason, among others.
Rich
13qtr
Oct 28, 2016 08:11 PM
2QUIK6
Sep 17, 2016 02:31 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
94Form
Jul 17, 2015 10:56 PM
Fastbird93
Jul 11, 2015 04:37 PM
