Something weird just happened....
Old Oct 29, 2006 | 10:36 PM
  #46
Sweetred95ta's Avatar
You'd be able to feel it if you put your hand over the oil fill opening.
Old Oct 29, 2006 | 10:45 PM
  #47
MeanGreen97Z's Avatar
I can see oil puffs slightly from the intake manifold gasket area. I think it's just suction.
Old Oct 30, 2006 | 12:29 PM
  #48
OK.... so I found the issue.... I'm this cars worst enemy. HAHA So a couple weeks ago I deleted the PCV (or what I thought was PCV). The tube that goes from the TB to the valve cover broke from being brittle when I pulled the TB off. I replaced it with a real PCV valve and a hose. Well it kept popping off so I plugged the hole in the valve cover and capped the TB hole.... bad idea. Heavy vacuum was building up in the motor and when it got to a certain point the car would die and it wouldn't start again until the pressure was released. It's all good now. I need to replace the intake manifold gasket now, but I found the problem. I ordered a new racetronix fuel pump and new opti already. Oh well .... i'll install them anyway.
Old Oct 31, 2006 | 10:04 AM
  #49
Heatmaker's Avatar
Advanced Member
Originally Posted by MeanGreen97Z
Opti is EASY as pie man!!! I got the racetronix pump and wiring kit. Cost me 250$ so it's not terribly cheap but better than needing a motor. LOL
It's Easy... it's just problem of removing half your engine bay to get to it.
Old Oct 31, 2006 | 01:57 PM
  #50
SS RRR's Avatar
fan shroud, pulley and waterpump is half your engine bay?
Old Oct 31, 2006 | 02:04 PM
  #51
I dont even remove the fan shroud.... LOL
Old Oct 31, 2006 | 02:24 PM
  #52
I was going to write the same thing, but I refrained. Don't forget intake bellow and radiator hoses (one side at least).
I think it's much easier taking the shroud out than cutting my hands on the damn plastic.
Old Oct 31, 2006 | 02:40 PM
  #53
No need when you are laying on the ground doing it from the bottom. SOOOOO much easier.
Old Oct 31, 2006 | 02:52 PM
  #54
SS RRR's Avatar
I just like the extra room. Especially when getting the bolt behind the PS pulley. It takes seconds to remove so it makes my life that much easier.
Old Oct 31, 2006 | 03:16 PM
  #55
Ya that bolt behind the pulley pisses me off. I always drop it and have to go hunting.....
Old Oct 31, 2006 | 04:45 PM
  #56
Heatmaker's Avatar
Advanced Member
I SWEAR!!! I knew somebody was going to say that.
Changing the opti is annoying. Don't forget gettign the annoying pully off, taking away the annoying air pump, removing the tedious brackets to get to the WP in the first place, then removing the pump, then getting the coolant everywhere, then taking the hoses off the opti, then aligning it, then vice versa of everything... I never look forward to the job. let's just say it involves more than simply pulling it off, and putting it on.
Nayr
Mar 3, 2023 08:34 PM
BigED
Jun 26, 2015 10:58 PM
Zuvell
May 15, 2015 08:18 PM
reww86
Apr 27, 2015 05:17 PM
97z28k&N
Jan 9, 2015 04:58 AM
