SLP Take-out Posi Install?
Old Jul 31, 2003 | 03:49 PM
y5e06's Avatar
I'll be installing an SLP takeout posi (from '99+ f-bodies) into a friends LT1 4th gen. His car has the stock auburn (?). Any tips/tricks to installing this posi? I've heard that the only thing that really needs to be done is to check the backlash. Is this right? How do we go about doing this for this particular case?
Old Jul 31, 2003 | 05:46 PM
Ryanzee's Avatar
just put one in last weekend!!
I also installed Richmond 4.10 gears.
If you are using the same gears the backlash will probly be out.
mine was at .007 stock and .016 after (with new gears).
If it is out try and use original shims (one piece) not a build up of different sizes. Luckly a mechanic I know had a box of them to chose from. Thanks Al. Use synthetic 75w90 gear lube and limited slip additive and go have fun.
Good luck
RYAN
Old Jul 31, 2003 | 06:34 PM
y5e06's Avatar
stock gears, have install kit too which I think comes with extra shims, new pinion seal, and some other stuff. How do you check backlash?
Old Jul 31, 2003 | 06:53 PM
rskrause's Avatar
Moderator
I don't like synthetic gear oil. It's too slippery. Use dino juice for your "rear end".
Rich Krause
Old Aug 1, 2003 | 07:00 AM
IDOXLR8's Avatar
Backlash is not the only thing to check for. You also need to check your wear pattern. Have you ever setup a rearend before? Good luck, take your time and have fun.
Old Aug 1, 2003 | 07:22 AM
1Z2Z's Avatar
Brent Franker's website has a good gear install guide that will tell you what you need to know. Mike
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
QuickSilver02
Apr 7, 2015 11:12 AM
TitoPR221
Jan 29, 2015 08:00 PM
