SLP line lock and Hurts shift knob
Old Jan 27, 2005 | 09:11 PM
Wicked 97TA's Avatar
SLP line lock and Hurts shift ****
Is there a way to hook the SLP line lock kit up to work with a Hurst shift **** with the 12 volt button?
Old Jan 27, 2005 | 10:56 PM
Crazy95Z's Avatar
Re: SLP line lock and Hurts shift ****
Yea I would think there is, if there is leads from the shifter itself just run the positive to the positive on the line lock kit. It should work but I haven't ever seen any Hurst ****'s with a button. Do you happen to have a link? I would like to buy one for my nitrous purge if it's possible. Thanks
Old Jan 27, 2005 | 11:01 PM
The SLP kit includes some sort of button or switch to activate the solenoid. I would assume they give you wiring instructions. Simply substitute the two wires attached to the Hurst push button in place of the two wires that would attach to the SLP switch.
Hurst sells both a T-handle style, and a round ivory **** with the 6-speed logo, equipped with a momentary contact button.
Old Jan 28, 2005 | 03:21 PM
Just go to Jegs.com and do a search on Hurst and you can find the ***** there.
Old Jan 28, 2005 | 06:04 PM
MellowZ's Avatar
Are Hurst ***** compatible with 4L60Es? Last time I looked for an aftermarket shifter **** (a few years back), none were compatible because of the reverse safety switch on the stock shifter.
Victor Lamb
Aug 26, 2017 02:52 PM
mattstrike
Mar 11, 2015 07:33 PM
Jason Short
Jan 19, 2015 06:34 PM
redz_02
Jul 24, 2002 09:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
