single plane intake
Old Jun 12, 2008 | 12:43 PM
BrooKLyn's Avatar
single plane intake
Ok i ready all 3 pages of post
My question is is there a direct bolt on single plane intake that would work great would no modifications ? for Lt1
Old Jun 12, 2008 | 03:19 PM
rskrause's Avatar
Moderator
Not as far as I know.
Rich
Old Jun 12, 2008 | 04:23 PM
slomarao's Avatar
I think your trying to say "is there a single plane intake that will work on a lt1 without modifying it"
The answer to that question is no. All of them are made to fit tradational sbc's. You could have a custom intake made that would fit without modification but that would be pricey.
Why do you want one? You would make more power with a cylinder head upgrade.
Old Jun 13, 2008 | 08:21 AM
BrooKLyn's Avatar
Cause im going to run a nice f1r and would like the single plain to stuff the air threw
Old Jun 13, 2008 | 08:25 AM
rskrause's Avatar
Moderator
It is not the hardest job in the world, but you need decent machining skills to convert a Gen I intake for use on an LT1. If you need to ask about it here, you probably need to have a machine/speed shop do the conversion. It would be something I would have done, for sure. If I tried it, it would take days and I would likely screw up at least one intake before I got it right. Maybe a couple, which would get very time consuming and expensive. As you probably have already figured, it's going to be tall with an elbow on top, so I hope you have a big cowl hood.
Rich
Old Jun 13, 2008 | 08:51 AM
WS Sick's Avatar
An alum wire welder is your best friend.
Old Jun 13, 2008 | 09:12 AM
slomarao's Avatar
I dont recall of the top of my head but i know there are a few companies that do them. I know ive read a few posts about Bret Bauer doing them.
Pretty sure phil at AI had done a few also.
Are you set on a single plane or would you consider a sheetmetal intake?
What about a wilson or hogan? (dont know much about these other than the names, they may be single planes or sheetmetals)
Old Jun 13, 2008 | 09:35 AM
rskrause's Avatar
Moderator
A nice Wilson is going to set you back at least $2K!!!
Rich
Old Jan 5, 2010 | 01:37 PM
BrooKLyn's Avatar
I had a super vic drilled and its to tall since its a dominator!! Wouldnt it be easy to just drill the heads to sbc and be done?
Old Jan 7, 2010 | 12:35 PM
T/A KID's Avatar
I did my own conversion and it came out great, even built my own elbow, and a custom valley/head spacer to increase runner length. I didn't drill the heads or do the intake. I bought some some stainless steel 30 degree washers and that fixed my bolt angle problem and it looks very clean.
I am running a super vic for a vortec engine (slightly taller than a SBC super vic) and between my elbow, 5.63inch super vic, and a 3/8 spacer it fits my stock Ws6 hood (LS1 front end conversion).
Looks killer and I have less than $400 in the whole thing
Dmonty
Jun 2, 2015 11:19 PM
TitoPR221
May 26, 2015 12:20 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
