Should I replace the coil??
Old May 21, 2005 | 04:12 PM
LUDA0840's Avatar
The coil has been in the car since it was built. Should I replace it? if so what do you guys recommend?
Old May 21, 2005 | 06:21 PM
LUDA0840's Avatar
Re: Should I replace the coil??
car kinda hesitates when I give it gas between 5 - 10mph. Or when I punch it at 25mph
Old May 21, 2005 | 06:39 PM
AF96Z28's Avatar
I like my MSD Blaster, I don't really know that would be the coil, but they're cheap so try it
Old May 22, 2005 | 10:56 AM
LUDA0840's Avatar
the car only has 1 coil right? Should I get a stock one or dish out a few more bucks for a performance one?
Old May 22, 2005 | 11:18 AM
Z28WannaB's Avatar
You'll find people go both ways on coils, some people say it makes no difference some say it does. No one ever provides supporting evidence, some manufactures like MSD make claims that their product is superior however you will not see an increase of power if thats what you are suggesting.
Yes there is only one coil, its located next to the water pump on the drivers side
Also why do you believe the hestitation is due to the coil? It could very well be a number of other things related to your ignition, like the opti for example.
Its cheap, I'd say go ahead and replace it with an aftermarket one if it gives you peace of mind.
- Z28WannaB
Klypto
Mar 23, 2016 09:05 AM
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
