Shavings in oil (very small amount) - normal?
Old Oct 12, 2004 | 07:49 PM
  #16
Cmr0z28's Avatar
Re: Shavings in oil (very small amount) - normal?
Took the filter apart...there was a few tiny specs in the bottom, a few in the top. They are not magnetic.
Old Oct 12, 2004 | 08:00 PM
  #17
Cmr0z28's Avatar
http://www.photohost.org/gallery/data/500/54682b.jpg
http://www.photohost.org/gallery/data/500/54681b.jpg
Old Oct 12, 2004 | 08:06 PM
  #18
atljar's Avatar
Normally when you get some serious bearing wear or the likes, you get a greyish coat of nastiness on things. So far your stuff looks good, but i would still be a little concerned personally.
May want to run a flush through the engine (seafoam in oil), and immediatley drain it after 5 min or so of running. That should grab any crap and get it out of there. Cant hurt. Then just keep a watchful eye out on your next change.
Old Oct 12, 2004 | 08:14 PM
  #19
Mtrhds94Z's Avatar
Never knew that..
Thanks!
Charlie
Old Oct 12, 2004 | 09:08 PM
  #20
atljar's Avatar
Glad I could expand your knowledge for the day. hehe. Have a good one.
Old Nov 10, 2004 | 03:12 PM
  #21
MTL_Z28's Avatar
Ok I did a search and came upon this thread.
I changed my oil today before storing the car for winter and as I pulled the plug (magnetic) I noticed that there was a coat of greyish stuff that people seem to be talking about as well as 3-4 metal shavings (1/8 of an inch in length) on the plug. It's been about 1200 miles since the head/cam swap. The oil pressure has always been and is still very good (55 psi cold start, 30 psi warm idle)
About 300 miles after the swap, I changed the castrol 10w40 non-syn that my mechanic put in (his recommendation) for some mobil 1 10w30 and K&N filter that I thought would be better. When I did change it the first time, there was nothing on my plug. Although keep in mind I did baby it the first few hundred miles and my car has seen track time and dyno time after that.
Is it normal?
PCLZ28
Dec 24, 2015 05:19 PM
ad356
Apr 11, 2015 08:49 AM
Brake_L8
Jan 20, 2015 09:44 AM
Sandersen511
Jan 13, 2015 03:49 PM
trefidy
Jul 26, 2002 03:40 PM
