SeS light came on it read transmission temp sensor.
Old Apr 10, 2019 | 08:28 PM
Dtredz28's Avatar
Please help. I had a ses come on in my 95 automatic
Z28 transmission temp sensor? Is there a such sensor I tried to look it up on line it comes back as coolant temp sensor. I know where these are but i dont want to change them if its not them. Thank you
Old Apr 10, 2019 | 09:03 PM
Re: SeS light came on it read transmission temp sensor.
What is the exact code number?
Old Apr 11, 2019 | 11:34 AM
No need to look it up online. Shoebox has a code list SPECIFIC to the LT1 PCM:
http://shbox.com/1/Dtcs.htm
If you want a detailed description of the code, what sets it, and what it takes to fix it, there's a free download of the factory service manual for your car, here, courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
In the meantime, yes, there is a transmission fluid temp sensor inside the transmission. It is part of the transmission fluid pressure switch assembly. But until you answer Shoebox's question on the exact numerical DTC, it's very difficult to help you.
Old Apr 11, 2019 | 02:41 PM
Dtredz28's Avatar
I will be taking it to my buddys today he has a code scanner. I will post it later. Thank you.
Old Apr 12, 2019 | 05:12 PM
Dtredz28's Avatar
Update check engine light is on its is reading communicate error. I took it to the shop. Not good with electrical.
Old Apr 12, 2019 | 05:17 PM
We’re you possibly using an OBD-2 scanner? If so, that’s a common mistake, but your 1995 is OBD-1 with a 16-pin OBD-2 “style” DLC connects. Means you need an OBD-1 scanner with a 12-pin to 16-pin adapter, or a 16-pin cable.
Old Apr 12, 2019 | 05:20 PM
Dtredz28's Avatar
My buddy has a scanner that normally reads it. But this time it wouldnt plus its in limp mode. I already replaced the ecm.
Patricklt1
Jun 27, 2014 02:02 PM
Red-LT1
Mar 21, 2007 04:29 PM
Showme
Oct 23, 2004 08:28 AM
greenZ94
Apr 29, 2003 11:18 AM
Stephen 98z28
Feb 21, 2003 05:16 PM
