P0117....How can I fix it.
Old Oct 21, 2004 | 09:53 PM
Showme's Avatar
Hey,
This is the code that tripped my SES light today. P0117-Engine Coolant Temp. circuit low input. Basically, how can I fix this without sending the pcm off again to have it deleted out or disconnecting the neg. battery cable everytime it comes on? I had the code cleared at Autozone, but I know it will eventually come back. Is there any adverse affects of engine performance when this code is tripped?
Thanks,
Tim
Old Oct 21, 2004 | 10:17 PM
ChrisS95TA's Avatar
Re: P0117....How can I fix it.
You have to change the sensor if it is bad, my car barely started when reading low or high voltage coolant temp sensor, same code. Cheap sensor right in water pump.
Old Oct 22, 2004 | 02:44 PM
Critical sensor.... not something you would "program out". If you want to check it, go to my online scanner writeup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
There's a table in there of sensor resistance vs. temperature, that will allow you to check it with an ohm meter.
Old Oct 23, 2004 | 08:28 AM
Showme's Avatar
Thanks guys
-Tim
Klypto
Mar 30, 2015 02:09 PM
IRABuss
Sep 7, 2011 09:08 PM
DougJ
Aug 29, 2002 12:51 AM
red
Aug 9, 2002 07:25 PM
MislMan
Jul 19, 2002 11:41 AM
