SeS light came on it read transmission temp sensor.
Please help. I had a ses come on in my 95 automatic
Z28 transmission temp sensor? Is there a such sensor I tried to look it up on line it comes back as coolant temp sensor. I know where these are but i dont want to change them if its not them. Thank you |
Re: SeS light came on it read transmission temp sensor.
What is the exact code number?
Originally Posted by Dtredz28
(Post 7002418)
Z28 transmission temp sensor? Is there a such sensor I tried to look it up on line it comes back as coolant temp sensor. I know where these are but i dont want to change them if its not them. Thank you http://shbox.com/1/Dtcs.htm If you want a detailed description of the code, what sets it, and what it takes to fix it, there's a free download of the factory service manual for your car, here, courtesy of GaryDoug: http://www.mediafire.com/?40mfgeoe4ctti In the meantime, yes, there is a transmission fluid temp sensor inside the transmission. It is part of the transmission fluid pressure switch assembly. But until you answer Shoebox's question on the exact numerical DTC, it's very difficult to help you. |
I will be taking it to my buddys today he has a code scanner. I will post it later. Thank you.
Update check engine light is on its is reading communicate error. I took it to the shop. Not good with electrical.
We’re you possibly using an OBD-2 scanner? If so, that’s a common mistake, but your 1995 is OBD-1 with a 16-pin OBD-2 “style” DLC connects. Means you need an OBD-1 scanner with a 12-pin to 16-pin adapter, or a 16-pin cable.
My buddy has a scanner that normally reads it. But this time it wouldnt plus its in limp mode. I already replaced the ecm.
