Code 14 Engine Coolant Temperature
Old Mar 19, 2007 | 04:16 PM
Red-LT1's Avatar
So the other day my SES light came on and I scanned it and its Code 14. This means that it was sensing above 284 degrees if I remember correctly. I checked it and it was stuck at 304 degrees, so I guess my sensor is toast. It still displays the right temp on the dash though. So which sensor is this, the one by the water pump?
Old Mar 19, 2007 | 05:09 PM
mdenz3's Avatar
Correct! But before you buy a new sensor give the old one a quick OHM check to make sure its not a wiring issue.
Old Mar 19, 2007 | 08:13 PM
OBE1 95Z28's Avatar
Shoebox has a good troubleshooting guide for this here: http://shbox.com/1/4th_gen_tech2.html#ect
Old Mar 19, 2007 | 10:00 PM
LT1_383's Avatar
The dashboard gauge uses the sending unit in the drivers side head. I believe the sensor for the PCM is on the water pump.
Old Mar 21, 2007 | 04:29 PM
Red-LT1's Avatar
Thanks for the help guys
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jazsun
Dec 29, 2014 12:14 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
