searching for the best spark plug wires
Old Mar 27, 2006 | 11:14 PM
  #46
firebirdStud's Avatar
Re: searching for the best spark plug wires
what is the difference between 300+ and the 9000's? I didn't know they (accel) made different series too... crap. How are they different?
Old Mar 28, 2006 | 03:31 AM
  #47
camarokid24's Avatar
Taylors here no problems what so ever, unless you count the pain in the butt opti ends. Trick is wd40.
Old Mar 28, 2006 | 05:18 AM
  #48
thesoundandthefury's Avatar
The 9000 series wires come with a heat reflective coating on the boots that withstands 1000F. Also, the 9000 series are 8mm while the 300+ wires are 8.8. Since you're doing an OTVC setup, I'd go with a universal set of the 300+'s. (The 300+ wires are resistant to 600F, which is plenty.) I've used three sets of them over the years and haven't had the first problem. Another thing I like about the 300+'s is that the silicone skin on the wires is nice and pliable so installing the boots and terminals is a breeze. They also don't dry out like the Taylors and MSD's.
Oh yeah one last thing: out of the 7 layers of different material used to make the 300+ wires, 4 of them are for insulation.
Old Mar 28, 2006 | 08:12 AM
  #49
wrd1972's Avatar
Does the Accel 300+ universal set come with the opti-ends already installed siilar to the MSD universal set? Or do you have to install both ends?
Old Mar 28, 2006 | 02:57 PM
  #50
You install both ends. The reason for this is because the universal set comes with a choice of terminals based on what type of distributor you're going to use. But like I said, the terminals and boots are really easy to get on.
Old May 6, 2006 | 11:36 AM
  #51
klrz28's Avatar
where did you get your ls1 coils from? i want to do the ltcc setup...
Old May 22, 2006 | 09:07 AM
  #52
94badrag's Avatar
Is Thunder Racing the only place to get the Magnecor wires?
Is can find only a precut set for headers. Are these the OTVC ones?
If not, were can I find OTVC Magnecor wires?
Old May 22, 2006 | 09:18 AM
  #53
bdc95ta's Avatar
Your going to need a custom set, http://www.magnecor.com/.
-brandon
Old May 22, 2006 | 01:06 PM
  #54
00JoeZ28's Avatar
What you need is some taylor "409" wires. 10.4 mm thick as sh*# wires.
I ran them on my old SS and never had any problems what so ever. As a matter of fact they were the last wires I ever bought for the car before it was gone. I was running them for about a year or so. Go with Taylor 409's
Old May 22, 2006 | 09:07 PM
  #55
I ended up goin with the MSD superconductors, but the OTVC routing this time. I am gonna take care of those damn headers eating my wires once and for all!
Old May 23, 2006 | 01:48 AM
  #56
SEMPER FI's Avatar
Which MSD wires would be long enough for the OTVC setup???
Old May 23, 2006 | 07:18 AM
  #57
Stroked94z's Avatar
I had Taylor wires on my old setup and put the MSD wires on the new setup and the only problem I had was that the wires were too close to the headers so I bought wire sleeves to keep them from melting. Other than that, no problems at all.
Old May 23, 2006 | 11:09 AM
  #58
SEMPER FI's Avatar
cool, so i can use the MSD 8.5mm and they will be long enough to use with the Over The Valve Cover kit. cause thats what i have right now and dont want to buy new wires just yet.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
