Rear main seal driving me CRAZY!
Old May 23, 2006 | 12:43 PM
Loadre's Avatar
So I've always had a leaky rear main. Absolutely positive that's what it is. Nothing else is leaking. Oil is thrown onto the pass side header at the exact line where the bellhousing meets the block. Throws it down the passenger side exhaust and undercarriage but not the drivers side. Oil drains down the converter cover and comes out of the little hole.
So I decided to replace it. Well, I just got done putting the tranny back in for the 3rd time in two weeks (thats how many times I've replaced the rear main) to no avail. Bastard leaks worse than ever. First time I just drove the seal on. Second time I used a small screwdriver to make sure the lips were seated corrected. Third time I lowered the oilpan and took the RMS housing off and drove the seal in, then slid it back on the crank and bolted everything back up. I'm at a loss. The crank has a SLIGHT SLIGHT groove that you can only see with your eye but cannot catch a nail on it or feel it. Should I still go ahead and sleeve it? How do I go about doing this?
Any comments are appreciated as I am at a loss.
Old May 23, 2006 | 12:46 PM
Javier97Z28's Avatar
Moderator
Re: Rear main seal driving me CRAZY!
Could be the oil pan gasket too? I replaced my rear main seal a couple years back thinking it was that but it turns out it was my oil pan gasket.
I think (fortunately) my new oil pan and gasket is not leaking.
Old May 23, 2006 | 12:52 PM
Loadre's Avatar
What were the symptoms of your leak if you can remember? I would LOVE to replace the pan gasket instead of pulling this tranny again.
Old May 23, 2006 | 12:57 PM
Moderator
Everyday I would have 3 or 4 drips of oil on the floor, the inspection plate on the tranny would also have oil in it. Tranny pan and ypipe constantly covered in oil.. etc.
Also, you could peek up at where the oil pan gasket meets and you could see oil squeezing out of it.
I had better luck with the OEM gasket than the blue felpro gasket.
Old May 23, 2006 | 01:06 PM
Loadre's Avatar
Would oil also drip onto the floor from where it collected on the tranny pan, etc?
There looked to be some oil possibly squeezing out but I thought it was just where it was leaking down off the RMS. There definetely looked to be oil at the bottom of the RMS every time I pulled off the flexplate.
I need to go see if anybody has that UV dye and solve this once and for all.
Old May 23, 2006 | 01:13 PM
Moderator
yep!
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
