scan/real time software
Old Aug 31, 2007 | 10:35 AM
raroz28's Avatar
What setup are most of you guys using?
I was thinking about buying a data cable, just curious what you guys are using with it.
It's a 97 with odb2.
Old Aug 31, 2007 | 10:39 AM
94_PatriotRed_Z's Avatar
Datamaster
Old Aug 31, 2007 | 10:52 AM
JP95ZM6's Avatar
I got the AKM USB cable, and it works great. I'm using Freescan for now, but might get TTS because it has more data available and lots of nicer features, like showing what BLM cell you are running in realtime, for example. Tunercat is good, too, for tuning.
Old Aug 31, 2007 | 11:45 AM
Sweetred95ta's Avatar
They don't have a Datamaster for OBDII (I don't think anyway). You'll have to use EFILive or something similar. It'd cost you less if you just converted to OBDI. There are copies of Datamaster EE floating around here.
Old Aug 31, 2007 | 11:54 AM
JP95ZM6's Avatar
Whoops, I didn't notice you are OBDII. Disregard my above OBDI advice. Sorry.
Old Aug 31, 2007 | 12:43 PM
JoeliusZ28's Avatar
do you use your setup for re-flashing as well? Ive heard there are stability issues with USB on OBD1. Ive been looking for an old laptop for this reason, but should i just get the USB cable?
Old Aug 31, 2007 | 01:00 PM
OBD-II scan software. Cable comes with the software package. I use this on my 02 Silverado.
http://www.autotap.com/
Old Aug 31, 2007 | 02:29 PM
raroz28's Avatar
Wow, only $200 for everything. Is it possible to use the cable they provide with another program, like LT1_Edit?
Old Aug 31, 2007 | 02:49 PM
jsetzer's Avatar
I use megatune most of the time, it records the logs all fancy like hp tuners.
Old Aug 31, 2007 | 03:14 PM
<Puck>'s Avatar
I use tunerpro RT for my scanning. I used to tune with it too, but I do not use my burnable chip and programmer anymore since my dyno tune(93 LT1 = chip, tuner needed stock chip for realtime emulating to ecu). I loved it for tuning.
It is not nearly as pretty as datamaster when scanning, but can monitor every value from the computer, and the dashboard feature is nice. I just wish you could set the dash to more then six sensors at a time though.
To be honest, the biggest reason I use it is that it is free and came with my chip burner package from moates .
Old Aug 31, 2007 | 03:36 PM
Other possibilities for OBD-II:
http://www.auterraweb.com/
http://www.obd2.com/
http://www.qcontinuum.org/obdgauge/
http://www.palmerperformance.com/
http://www.monodax.com/
Old Sep 1, 2007 | 11:19 AM
KPZ-28's Avatar
Do you have serial or usb? Which do you recommend.
Old Sep 1, 2007 | 02:21 PM
raroz28's Avatar
USB is always better. Some new laptops don't even have serial equipped. I had to let my buddy use my laptop for his microtek tuning because his laptop had no serial port.
Old Sep 1, 2007 | 08:14 PM
JoeliusZ28's Avatar
is this the case for OBD1 though? I know USB is better for OBD2
DirtyDaveW
Dec 1, 2016 05:37 PM
383TransAm
Parts Wanted
Feb 15, 2015 05:05 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
