running rough after cam swap???
Old Jul 26, 2010 | 06:19 PM
jklopez09's Avatar
did a cc305 cam swap on my 93 z28 awhile back and since its not really drove i just crank it every now and then. But anyways since the swap it has been acting like its not getting gas( I THINK). it always fires straight up the first time but sometimes when i crank it twice i have to tap the gas pedal. if i put it in gear and start to give it a small amount of pedal, the it hesitates and sometimes pop i think from intake. but this only happens during lower rpms. it revs up and drive fine above about 2000 rpms. im thinking that the timing may be off but not sure. PLease help me figure this out so i can start driving it.
Old Jul 27, 2010 | 08:47 AM
jklopez09's Avatar
which of the following do yall think may be causing the problems: timing chain not lined up right, opti not lined up right, or the rockers set wrong?
also i cranked it last night and where the egr tubes were welded closed i could see blue(sparks?) and somes plug wires i could see the spark running thur them, but the car does not feel like its missing.
Old Jul 27, 2010 | 09:07 AM
The post is a bit confusing - might want to clarify. You indicate "its not really drove i just crank it every now and then", but then you say "it revs up and drive fine above about 2000 rpms.".
Also confusing when you indicate "it always fires straight up the first time ".... but then you add "but sometimes when i crank it twice i have to tap the gas pedal."
Your reference to the sparks at the "EGR tubes" would appear to mean the AIR connections. If you see sparking on the headers and along the plug wires, it would explain the "pop I think from the intake". I'd get rid of the sparking, before assuming you have a problem with the timing chain, or Opti indexing. Sort out one problem at a time.
Old Jul 27, 2010 | 09:40 AM
jklopez09's Avatar
sorry about the confusion. what i meant is that every so often i will crank it up and let it idle and sometimes i will drive it down the dirt roads. when i do drive it sometimes it will stall and in order to crank it, i have to give it some gas. the plug wires have always arced even brand new msd wires and i just seen that i have exhaust leak where the tubes were welded closed on the headers. also i am getting codes 12 and 15 when i scan it.
Old Jul 27, 2010 | 12:31 PM
jklopez09's Avatar
well the temp sensor on the water pump was unplugged so plugged it back in and the SES light went off. could that have been causing it run bad?
Old Jul 27, 2010 | 03:22 PM
Yes. The computer needs to know the coolant temperature, so it can set the cold start enriched air/fuel ratio.
The "12" code just tells you the ECM has entered diagnostic mode.
Old Jul 27, 2010 | 03:28 PM
n2ceptor's Avatar
Have you reset the computer since plugging in the temp sensor ????
Old Jul 27, 2010 | 07:51 PM
jklopez09's Avatar
to reset the computer, just disconnect the battery for a few hours right??? i will try it tomorrow after work.
Old Jul 27, 2010 | 09:37 PM
n2ceptor's Avatar
Fuse panel-- remove ECMBATT fuse for 10 seconds, replace....
Old Jul 28, 2010 | 06:10 PM
jklopez09's Avatar
Thanks for your help. after i hooked the battery back up, it is running much better.
parkers Z28
Mar 11, 2016 08:14 PM
chuyz28
Jan 15, 2015 04:14 PM
1775.Z28
Jan 11, 2015 10:51 AM
cmdeshon
Dec 12, 2014 10:51 PM
chuyz28
Nov 25, 2014 11:14 PM
