new camshaft and lifts
Old Dec 22, 2014 | 05:23 PM
1775.Z28's Avatar
Hey guys, I have a 1997 Camaro 5.7/350, I want to put a new camshaft, lifts, and roller rocker arms in it. I need advice on what cam I should run in it. I don't want it to run too rough but to sputter a little. So any advice out there as to what brand/size cam I should run. Thanks!
Old Dec 22, 2014 | 05:42 PM
Chimera96's Avatar
Re: new camshaft and lifts
need more info on what other mods have been done to the motor...
if still stock heads, stall, gears you will need to stay on the smaller side for cam
check out Lloyd Elliott (LE Portworks) or Advanced Induction for a custom grind suited for your existing mods
There are a few off the shelf cams but for the $100 cost difference if that a custom grind from one of those two will provide more power
you will need a new PCM tune for any cam you get
Old Dec 23, 2014 | 01:12 AM
1775.Z28's Avatar
Thanks....its all stock right now except for a catback exhaust
I talked to a tech/sales guy at comp cams and they recommended this one...any opinions?
thanks again!
Xtreme Energy™ 266HR-14
Original LT1 w/ Stock Computers
07-304-8 - Xtreme Energy?
Old Dec 24, 2014 | 01:59 AM
97WS6SCharged's Avatar
The 304 is pretty small. It'll drive pretty much exactly as it does now. Wouldn't expect much sound out of it.
Most guys run the slightly hotter 305 cam in daily drivers.
07-305-8 - Xtreme Energy?
Old Dec 24, 2014 | 09:18 AM
Selecting a cam based on wanting it to "sputter a little" is not the best way to proceed. The "sputter" comes from high valve overlap. High valve overlap typically produces poor low RPM torque, for the benefit of more very high RPM HP. Doesn't make any sense.
Old Dec 25, 2014 | 05:11 AM
A little sputter is fine. It's when you pick your cam by going to the bottom of the cam page in the catalog that you start getting into trouble.
Or you can cheat.
"Little" 235/247 duration in my DD at 65% throttle (17 year old throttle cable had stretched).
Old Jan 11, 2015 | 10:34 AM
1775.Z28's Avatar
Thumbs up Re: new camshaft and lifts
This is the 305 cam.....
Xtreme Energy™ 276HR-14
For Use w/ LT1 Modified Computer
what will I need to do for modifying the computer?
Thx again!
Old Jan 11, 2015 | 10:51 AM
Chimera96's Avatar
you will have to send your PCM to a mail order tuner or find a tuner/dyno to do it
with your cam and basic mods a mail order would be fine.
fastchip.com (Ed Wright) is who I use
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
